06-07 projector shroud fit 03-05 housing?
Old Sep 5, 2012 | 08:47 AM
TGMcCoy's Avatar
I have 1 06 headlight that is a little broken inside(the interior housing moves around a bit) and was wondering if any of the parts from the 06 light are interchangeable with an 03-05? the projector maybe? the turn signal lense etc? If so I may look for another broken one to complete both lights
Thanks for any helpful info
Old Sep 5, 2012 | 10:33 AM
Frankieg35's Avatar
I think it will work but u will have to mod some things..
Old Sep 5, 2012 | 01:38 PM
suprasam's Avatar
Off the top of my head the black housings are different for the projector and non projector headlight. The turn signal housings are not interchangeable for various reasons. You may be able to retro the projector into the 05 and lower but it will require a bracket of some kind. The bulb/reflector housing in the 05 is one giant bracket that the reflector bowls attached are attached. You can use the outer lens from the 06 on an 05.
Old Sep 5, 2012 | 06:41 PM
saywat?'s Avatar
^i recall reading somewhere that even the lens is a tad different
Old Sep 9, 2012 | 01:38 AM
TGMcCoy's Avatar
I just noticed this thread got answered! Thanks for the responses! Mabe I can fix the 06-07 headlight I have. I've never messed with any headlight modding or repair, but the inner chrome (housing?) along with the projector rattles around inside like just a cm or so. Seems like an easy fix, hopefully. Then I'll just buy a used left headlight to match
Old Sep 16, 2012 | 07:43 AM
TGMcCoy's Avatar
Anybody point to info on retrofit projector into 03 housing? Is it easier to put projector in the high beam reflector spot? I've noticed this being done...
Old Oct 5, 2012 | 10:20 PM
Mosheh1am's Avatar
I'm looking for an answer to that as well
Old Oct 5, 2012 | 10:31 PM
TGMcCoy's Avatar
I'm still looking.. I do have a pair of oem projectors in need of small repair(I think) bezel inside is broken some and moves around... My 03 reflectors are in great shape and wanted to retrofit if it wasn't too hard... But I think it will be, especially since I've never done any lighting projects lol
Jusseth
Sep 13, 2020 12:25 PM
Genthusiast35
Jan 19, 2016 02:19 AM
thewarden
Aug 30, 2015 04:00 PM
