Issue installing LED for 2004 G35X door/step lights
Old Sep 19, 2012 | 06:27 PM
djemzine's Avatar
Hello folks,
I am a new user to g35driver.com and I thought I'd ask you all a question regarding an issue I have.
I purchased 2 pairs of the SJ 6SMD-W LED lights for my car's door/step lights as I was recommended that they are universal for both the map/dome lights as well as the door/step lights by the retailer whom I bought it from.
I also did some online research and apparently they are 31mm festoons or whatever.
However, when I took apart the old/stock halogen light from the door light bay, and tried to insert the LED one, it did not fit as it was too big for it to fit in between the clips.
So my guessing is that I was given the wrong ones for the door/step lights and I should get smaller ones instead or am I doing it all wrong here?
Here is the pic of the light I bought vs the stock one in the car.
Thanks in advance!
Old Oct 4, 2012 | 12:10 AM
Canadiotica's Avatar
Mine were the same, but what I did was pull apart the copper clips the bulb seats into a tiny bit and they popped rite in and worked great!
Old Oct 4, 2012 | 10:11 AM
djemzine's Avatar
Did you use some sort of tool to pull apart the copper clips in the fixture or whatever? I don't want to touch it because power is going to it constantly unless I disconnect the battery...
Old Oct 4, 2012 | 04:43 PM
I just used a flathead screwdriver and my finger on the other side and spread it apart. I would be very careful because if you break it your kinda out of luck, but I doubt that will happen unless you bend it back and forth a bunch of times.
And I didn't run into any problems with the battery connected. If your worried about it you may have to unplug battery or do it while a rubber covered screwdriver.
Old Oct 13, 2012 | 11:59 AM
djemzine's Avatar
Al right so I managed to install the LEDs heh. You were right. They do fit. I just had to angle it properly so the light faces properly on the door/inside and it fit right in. No need spread the clips apart. Just popped it an voila.
Thanks again for the suggestion .
Old Oct 13, 2012 | 06:03 PM
Great to hear! Any night pics of the Led's? I still have to get around to taking pics of mine
Old Oct 13, 2012 | 11:15 PM
djemzine's Avatar
Ya I do actually but the quality is horrible, used a really old phone to take the pics heh.
Old Nov 8, 2012 | 07:13 PM
PlastiDippinG's Avatar
Originally Posted by djemzine
Hello folks,
Thanks in advance!
The LED strip itself is probably also causing touble with fitment
chinee
Jun 10, 2024 07:48 PM
Mry
Mar 3, 2023 01:03 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
igking
Jul 19, 2015 01:12 AM
