Questions with quad projectors, or new lenses and bulbs please help
Old Jan 30, 2013 | 10:52 AM
suprasam's Avatar
Here is my set up. I've since changed out the led halos. Like DKano all lights stay on as highbeams.
https://g35driver.com/forums/lightin...neak-peak.html
Here are the links I used for inspiration. The biggest thing for the 06-07 is the access hole and mounting points on the reflector are off center on the foglights. You have to make a custom mounting system to hold the projector housing. I tried moritmoto mini h1 which will fit the reflector housing but because it's off center didn't work at all. So thinking back when I had my 05 and 06 headlights apart, 05 and below is easier to retrofit.
With an additional set of 06 projectors.
https://g35driver.com/forums/lightin...tor-hls-d.html
With a different type of projector.
https://g35driver.com/forums/lightin...-retrofit.html
I hope this helps.
Old Jan 30, 2013 | 11:59 PM
guitarrocker98's Avatar
Ya it sounds like my 06 will be insanely hard to do. I may just pick up a set of 05's and then swap the plastics..... Or maybe I won't do quad projectors after all.....
Old Jan 31, 2013 | 12:11 AM
Frankieg35's Avatar
I don't think quads are worth all that, I used to want to do that mod but just gonna pick up an hid kit..
Old Jan 31, 2013 | 10:24 AM
DKano's Avatar
PM be in about a week if you still want quads, I'm going to have a set for sale.
Jusseth
Sep 13, 2020 12:25 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
