Quad reto fit parts list
Old Aug 6, 2013 | 10:53 AM
ivey_usmc's Avatar
I have a 05 coupe and i want to do a quad retrofit but ive neve done this before. Is there someone that can walk me through it and help me out where to buy parts and what parts I need? I love the look but I like to do things myself.
Old Aug 6, 2013 | 03:58 PM
DKano's Avatar
First you have to decide which projectors you want to use. Take a look at the ones on TheRetrofitSource site, that's where I get most of my parts. The low beam area is a little tricky to work with if you go with any projector that is not the Morimoto H1s. Anything bigger than those means that you're going to have to cut the stock housing to make the projector and shroud fit. The fog/high beam area is a little bigger and would be easier to fit a different projector there.
Up to you which projectors you want to go with, just remember that the stock housing is a little fragile and every time you cut it could mean that you'll end up causing it to crack somewhere. I've had that happen a couple of times.
Old Aug 6, 2013 | 07:07 PM
ivey_usmc's Avatar
ok. Thanks for the advise. Ill look there
Old Aug 9, 2013 | 10:37 AM
hdmark's Avatar
im going to be doing a low beam projector retrofit for my coupe. im gonna use RX-330's if that helps at all. they seem to be the best for the price. not too big. and great output.
on TRS though, ive seen a quad or two that used MH1's up top and TL's on the bottom for the dual.
Jusseth
Sep 13, 2020 12:25 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
DarkLyter
Jul 28, 2015 04:57 PM
joedaddy1
Jul 28, 2015 02:58 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
