Lights under the door
Old Mar 22, 2014 | 01:52 PM
Chrstian17's Avatar
Hi I was wondering if anyone has upgraded the lights that are underneath our doors when we open them, I'm pretty sure we would have to remove the complete door panel but after that is it pretty simple?
Old Mar 22, 2014 | 02:17 PM
JG_G35's Avatar
No need to remove door panel just pop off bulb lens cover with a flat head screw driver and switch out. More info in this link. https://g35driver.com/forums/showthr...982&styleid=51
Old Mar 29, 2014 | 02:02 AM
yar6rider's Avatar
Use small flat head screw driver pry each side at a time at the 90 degree curve. To easy to work on is pry out the bottom of your door panel (on the bottom you see little hole between door and panel that where your screw driver goes in)
Old Mar 29, 2016 | 06:49 PM
The Hawk's Avatar
Very simple fix. Lay on your back and open car door. Pop lens cover off with flathead screwdriver. Replace with LED from local parts store. You will be amazed at how much brighter it is.
Old Mar 29, 2016 | 07:40 PM
jimmyznutz's Avatar
Easy job. I replaced mine with some mini cob led panels. Extremely bright now. I'll post up a pic a little later.
Ninja edit:
Old Mar 29, 2016 | 10:10 PM
gary c's Avatar
Very simple 5 minute mod! I added super bright white (looks blue) LED bulbs...Gary
Old Mar 30, 2016 | 03:46 AM
Tyke420's Avatar
They even sell/ have the oh so cool INFINITI light that illuminates on the ground when your door is open. Install should be just as easy as everyone above explained.................
Old Mar 30, 2016 | 09:07 AM
yosip1115's Avatar
somebody plz link me... I sort of want these
Old Mar 30, 2016 | 09:42 AM
Lartytiejdke3's Avatar
youre better than that..
Old Mar 30, 2016 | 09:50 AM
yosip1115's Avatar
You're right. If only they came in pink.
I got those weds mounted with the MPSS 275's, I needed a serious pull. I'll post pics up soon
Old Mar 30, 2016 | 01:16 PM
sweetttt
mike730
Jan 12, 2018 04:25 PM
RA081024
Aug 18, 2015 07:03 AM
avalino
Aug 6, 2015 01:42 PM
