High beam works Low beam Doesn’t?
Old Apr 20, 2023 | 06:22 PM
Fabri1520's Avatar
Infiniti G35x sedan
Hello everyone I am having an issue with my driver side low beam. It won’t turn on after putting in a new fuse, new bulb and the ballast is probably a year old. I thought maybe the ballast was the problem but the high beam and LED’s work. The headlights are the spec-D ones with the one halo and LED on the side. Any help would be appreciated.
Old Apr 20, 2023 | 09:47 PM
05_SkylineSedan's Avatar
20 Year Member
If I remember right the 06 low-beam xenon bulbs are always-on and the high-beam halogens just add to the lows. There are many fuses involved so you might need to check the FSM which you can find her:
https://www.nicoclub.com/infiniti-service-manuals
Click through to find your model and year and then "Lighting System". Scroll to the bottom of that window and "Click here to download a copy". This will help you find all the fuses in the circuit. Hopefully that's the simple answer.
Old Apr 21, 2023 | 01:05 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Swap ballast, lamp from the other side of the car that you know works. Then you can verify the components are actually working in the first place.
Hall Stevenson
Dec 6, 2024 09:45 PM
aamir007
Jan 8, 2015 02:08 PM
ramskate
Oct 7, 2012 07:41 PM
Mark2K8
Apr 5, 2012 12:53 AM
nlallen141
Lighting
Jan 26, 2010 02:58 PM
