Interior Light help
Old Sep 23, 2005 | 10:08 PM
05GCOUPE6MT's Avatar
Interior Light help
I cold not find this on this sight and was hoping for your help.
I want to replace the Interior Lights with White/White PIA LED. I need the Numbers/type for the map lights, dome lights, sill lights & Trunk lights.
Thanks
I changed the clearence,Side markers, Fogs & Plate with PIA extreem White wedge bulbs and they look nice. I do not understand why they call them Exteem white Since they have a blue tint to them? Go figure....
Old Sep 24, 2005 | 02:44 AM
mrjonang's Avatar
Thanks
.. go search it, try the modification > lighting part of the forum, great amount of detail there on lights.
i just recently purchases map/step lights for my G from http://www.autolumination.com/ i belive its the 3022 size bulbs
the trunk light is the same as the clearance/strip/liscene plate,size 921.
Old Sep 24, 2005 | 08:24 AM
Did I get this Right???
Map & step Lights are 3022=PIA 19355 ( 4 bulbs ) correct
Tunk= 921 ( 2 bulbs ) Same as Clearence correct
Thanks for your help!!!
Old Sep 24, 2005 | 02:31 PM
izmir41500's Avatar
G35driver Addict
how much will all those bulbs cost if you dont mind. i'm contemplating this too.
Old Oct 15, 2005 | 11:27 PM
jerdubois's Avatar
I bought 8 bulbs from superbrightleds (3022 w/ 4 leds) from $22 shipped. Guys - why don't you do a google once in a while!!! Takes less time to find the answer then to type the question
Old Oct 19, 2005 | 04:56 AM
dofu's Avatar
20 Year Member
For some odd reason, the LED bulb replacements from superbrightleds aren't always as bright as some other LEDs available... but they sure are cheap!
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
zoop425
Mar 29, 2016 05:51 PM
derres
Aug 28, 2015 03:27 PM
Jadenkid22
Jul 14, 2015 12:33 AM
