03-05 Fog Light Conversion to Xenon??
Old Nov 8, 2005 | 03:30 PM
jcboizi's Avatar
Did anyone retrofit our fogs into xenons? I'm thinking of putting a xenon kit since our lights are not that bright. If someone did, please post some pictures. Thank you in advance!!!
JC
Old Nov 8, 2005 | 03:46 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
It's a work on progress for the 5th (!) revision of my retrofit, but here's a pic:
The low beams with the TSX projectors are done. The high/fog with RS6 bixenons need the shroud finalized and the wiring hooked up.
Attached Thumbnails 03-05 Fog Light Conversion to Xenon??-projectors-018a.jpg
Old Nov 8, 2005 | 05:07 PM
jcboizi's Avatar
That is beautiful. But I am assuming that retrofit will be very expensive. I was looking more like adding a xenon kit on our fog lights.
Old Nov 8, 2005 | 08:35 PM
jcboizi's Avatar
anybody else? =(
Old Nov 8, 2005 | 09:43 PM
TwoK4drSi's Avatar
I did. I put oem nissan hid's in them. They look awesome.
Old Nov 8, 2005 | 09:54 PM
M6_G's Avatar
Very well done.. Approx cost and time to finish the job?
Old Nov 8, 2005 | 11:06 PM
Balzac72's Avatar
G SQUAD
Ditto that! Whats your investment at this point?
Old Nov 8, 2005 | 11:57 PM
E_K's Avatar
E_K
So far it's:
$200 TSX projectors
$30 hidplanet shrouds
$25 two E46 3" shrouds
$200 RS6 bixenon projectors
$300 for extra pair of headlights with ballasts/bulbs.
$45 H4 harness that will allow both high (solenoid) and low (HID bulb) to be on at the same time.
$7 for an acrylic pane at Home Depot for the clear signals, with enough material left to do another 15-20 pairs of headlights.
2 months of time into it, creating custom sheilds for the TSX projectors, figuring out how to mount everything. I do about 1 hr of it here and there. It's just for my own car, so I'm taking my sweet old time. My goal is to finish it by early December.
Old Nov 9, 2005 | 02:56 AM
WaLLy's Avatar
So far it's:
$200 TSX projectors
i can already see the light out put now
keep us posted
Old Nov 9, 2005 | 11:45 AM
jcboizi's Avatar
Would you mind showing me some pictures and some mounting areas? As to where to mount the ballast and whatnot? Thanks!!!
Old Nov 9, 2005 | 02:11 PM
ISMSOLUTIONS's Avatar
So far it's:
$200 TSX projectors
With all that time invested and the bucks, woudln't it be easier to pop in the '06 headlights and be done?
Old Nov 9, 2005 | 04:26 PM
Gee Im Fast's Avatar
I think he started before the 06's were out and before anyone knew that they were plug and play...also, he still has his clearance light!
Old Nov 9, 2005 | 05:05 PM
E_K's Avatar
E_K
I already did a retrofit in Sept 2003, pretty sure I was the first to do so on a G35.
But I'm looking for a sharper cutoff with the TSX projectors.
Plus, if you look at the list of items, you'll see that there are a total of 4 projectors listed.
Jusseth
Sep 13, 2020 12:25 PM
zoop425
Mar 29, 2016 05:51 PM
Freddy07g35
Sep 17, 2015 08:53 PM
06G35Kurtis
Aug 23, 2015 12:24 AM
attarday
Jul 15, 2015 04:03 PM
