G35 Coupe Headlight Removal Guide (3 Simple Steps)
Old Nov 28, 2010 | 05:39 PM
  #166
swoo35's Avatar
Do you think you can re-upload pictures? They don't seem to work anymore
Old Dec 5, 2010 | 11:59 PM
  #167
surma884's Avatar
There seems to be wrong information about unplugging the harness and the DIY'er didn't explain it. Not a very good DIY.
So once you unscrew the 4 bolts on the headlamp if you try to pull the headlamp out it will not come out because the wiring harness is still plugged. There is not enough room to unplug it either. The reason is the connector is on a holster. It is secured to the headlamp so that the wiring harness doesn't move around. It is secured by sliding it on the "rail".
Here is how you remove it. When you are facing the headlamp, if you pull the headlamp out slightly you will see the connector. Use a flat head screwdriver and insert it between the connector and the headlamp. You will insert it to the side of the connector. You will use this screwdriver as a crowbar to slide the connector off. Tilt the screwdriver towards you so that the connector is pushed towards the back of the car. Once the connector has come off you can pull the headlamp out further and you will have much better access at unplugging the connector.
The release button for the connector is facing down so all you do is twist the connector up and then use a flat head screwdriver to push down on the release button and separate the connectors.
This is the proper way of doing it. I saw about 10 posts telling people to break it! That is not a good idea. The harness design is not bad, it was just bad information given out.
Old Dec 22, 2010 | 11:17 AM
  #168
acee's Avatar
Addict
Help!!!!!
HOW DO YOU REMOVE THE BALLAST? ON A 06 HEADLIGHTS? IM TRYIN TO TO BAKE EM BUT I NEED TO TAKE THE BALLAST OFF RIGHT? can someone help please
Old Dec 23, 2010 | 02:38 PM
  #169
surma884's Avatar
You take the 3 screws on the ballast, and of course make sure the gray connector on the side is removed as well. Then you slowly pull it out. Inside there will be another connector which you take out and you may also have a yellow ground wire. First remove the screw for the connector inside and then remove the connector. That is all you need to do.
Old Dec 30, 2010 | 09:13 PM
  #170
ODzZie's Avatar
Oh Man This is Incredible
Old Jan 10, 2011 | 04:12 PM
  #171
saywat?'s Avatar
so was there ever a diy install guide for the ccfl clearance strip mod? i wanna see wat it entails before even attempting it
Old Feb 18, 2011 | 02:31 PM
  #172
NFLDAD's Avatar
Red face Universal Lighting eyes Headlight Kit
I am considering purchasing this kit for my 2005 G35. I found it on CarID. I was looking for LED headlights and stumbled across this. I like the Audi Led light look. I was wondering did anyone else try this? The customer reviews were of the chain as a nice assessory.
Old Mar 29, 2011 | 10:54 PM
  #173
A BAD G's Avatar
Nice work bro
Old Mar 29, 2011 | 10:56 PM
  #174
PERKS11's Avatar
thanks i will need this over this weekend!!
  #175
jcseven7's Avatar
Thread posted 01-09-2006, 01:08 PM... just sayin'
Old Mar 30, 2011 | 12:11 AM
  #176
YT35's Avatar
its still a good thread for anyone thats removing for the first time
Old Mar 30, 2011 | 04:25 PM
  #177
jcseven7's Avatar
In fact, I used this thread when I modded my headlights.
I guess my point should have been more clear. OP hasn't been active for over a year, so he won't know you are thanking him...
Thanks a lot, YT35... now you made it weird!
Old Apr 28, 2011 | 12:23 PM
  #178
ChiBLKG35's Avatar
Not sure if this was already posted but here it is in .PDF format if you want to print it out like I did.
http://dl101.herosh.com/2b77c3165d93...ht.Removal.pdf
Old May 10, 2011 | 06:41 PM
  #179
johnug35's Avatar
hey, after install how can I adjust the aiming of the lights??? Is there a adjustment screw???
Old Jun 7, 2011 | 10:34 AM
  #180
buercky's Avatar
This was GREAT show me type.... Got my long extensions on my 10mm made those 2 screws on the front 1\4 panel come out very easy.
I also put tape the full length of the fender all the way to the tip and doubled it up to protect the paint.
