G35 Coupe Headlight Removal Guide (3 Simple Steps)
Old Feb 25, 2009 | 08:49 PM
  #106
kala1's Avatar
can someone pls tell me or show diy with pics on how to take the whole bumper off !
Old Feb 25, 2009 | 10:50 PM
  #107
BAND149's Avatar
very nice
Old Feb 26, 2009 | 03:46 PM
  #108
YT35's Avatar
1. open your hood
2. theres 6 plastic fastener, pop it off
3. fenders -3 more of those each side, pop it off
4. theres 2 bolts on each side on the inside on the fender wall, bend it a bit to reach them- they are both 10mm
5. then the bottom on the car of front bumper, all 10mm bolts, theres quite a lot few them, just take it all off
6. before taking it off, you shold tape the side bottom next to the headlights on the fenders because you might scratch it with your front bumper
good luck
Old Mar 9, 2009 | 06:48 PM
  #109
Sals G35 Coupe's Avatar
Great tutorial! I will be removing the headlights from my G to replace some bulbs and was curious if the headlights will need to be adjusted after reinstalling?
Old Mar 9, 2009 | 06:56 PM
  #110
YT35's Avatar
nope, plug and play, just tighten all the bolts, it should aim straight
Old Mar 9, 2009 | 07:51 PM
  #111
yourdoinitwrong's Avatar
Everything SHOULD go back in the same position as before but you should check anyway just to verify so you don't blind oncoming drivers, especially if you have the HID bulbs.
Old Mar 16, 2009 | 08:19 PM
  #112
HarrisonK's Avatar
nice write up, can you, or someone explain how to actually install HIDs or Demon eyes?
Old Apr 14, 2009 | 10:41 AM
  #113
PhillyG35's Avatar
How difficult is it to put back on the bumper? It looks like there would be a lot of propping up and stuff like that.
Old Apr 14, 2009 | 10:49 AM
  #114
If you go with the method described at first in this thread you do not need to entirely remove the bumper. Just make sure you protect the front fenders from being scratched by the edges of the bumper. If you take it all the way off then it won't be that hard to get it back on. Just have someone hold it in place while you attach enough of the fasteners/bolts to hold it in place. Then finish with the rest of the fasteners and bolts and you're done.
Old Apr 15, 2009 | 12:21 PM
  #115
LCA575's Avatar
Its easier if you have a helper, just reverse the steps to reinstall.
Old Apr 15, 2009 | 04:29 PM
  #116
visibiliti's Avatar
I've removed and reattached my front bumper quite a few times by myself. I agree with above that it is easier if you have a helper, but if you do not, just hold it in the middle and get it in place, then put the two top clips in place and then work from there.
Old Apr 29, 2009 | 08:25 PM
  #117
blaccG35's Avatar
what should you set the temp when you put it in the over??
Old May 5, 2009 | 12:19 PM
  #118
kzman70's Avatar
i tries to do this yesterday but i ran into 2 problems, i couldnt get the harness to unplug and i couldnt find a way to get the wire harness off the lights, i got all the bulbs out but there was one wire that is orange and i ran indise and i couldnt figure how to take if apart. can anyone help me. thanks
Old May 5, 2009 | 12:29 PM
  #119
If it is the one I think you are talking about my buddy and I had to use a pick to pull back the release clip so the harness would unplug, it was a pain. We went in from the back of the light and just kept at it until it finally released. It might take one person pulling a little bit on the harness while another person uses the pick to pull the clip away from it.
Old May 5, 2009 | 01:40 PM
  #120
YT35's Avatar
get a small mirror, then use a pick or a flat screwdriver, stick the mirror under, it made it much easier, seeing what's under
