G35 Coupe Headlight Removal Guide (3 Simple Steps)
Old Jul 5, 2008 | 09:08 PM
  #76
HoCkeYBrAhCA/MN's Avatar
Originally Posted by LCA575
Its www.aacstyle.com we do not have the CCFL Strips on there yet so if you want a set just pm me.
can you use the 06-07 in a 05? is it the bulbs or is it the complete headlight?
Old Aug 17, 2008 | 06:16 AM
  #77
idrive_MD's Avatar
another praise post for this sticky.
i wanted to replace the clear clearance strip bulp yesterday and thought i would just wing it, thankfully i wised up and used this sticky and it made things pretty easy...still a lot of work to change out $3 bulbs.
Old Sep 20, 2008 | 11:22 AM
  #78
HiRevTuneR's Avatar
Smile
Thanks for the tips!! I will start on this project and lets see how it turns out!!!
Old Sep 24, 2008 | 09:19 PM
  #79
Richard Su's Avatar
EXCELLENT POST! thank you for your time & effort in this
gets me thinking how to start working~
one noobish question though...those 3 screws in the fender well, how do you remove them such that they wont break? and if they break, where do I find a replacement? I broke like two of them when i tried to replace my clearance light ><
Old Sep 27, 2008 | 04:48 PM
  #80
crashnburn's Avatar
just got my 06 headlights and thank you for the write up....
Old Oct 21, 2008 | 10:02 PM
  #81
zeadlots's Avatar
Thumbs up
Just wanted to say thanks for the DIY. Used it tonight to wire my daytime running lights for my federal inspection.
Passed with flying colors!
Old Oct 22, 2008 | 10:58 AM
  #82
LCA575's Avatar
You are referring to the plastic rivets? I keep a big box of universal ones on hand, you can pick them up from O'Riley Auto Parts
Old Oct 29, 2008 | 03:21 PM
  #83
Blackedout's Avatar
Used this guide several times when I've painted headlights and installed new clearance strips thanks again.
Old Nov 2, 2008 | 11:16 PM
  #84
SixOneFive's Avatar
Pardon me for not reading through 6 pages of this thread, but how long and at one temperature should the lights be in the oven? Also, how do you re-seal the casings?
Old Nov 14, 2008 | 05:23 PM
  #85
YT35's Avatar
hey, how do u dissconnect the headlight harness?
Old Nov 14, 2008 | 05:32 PM
  #86
yourdoinitwrong's Avatar
This is the worst part of the whole thing. They don't give you hardly any extra lead on the wire and the clip is on the bottom! I had a friend helping me and I was holding the lamp assembly from the top and he was in the wheel well. He used a pick to unclip the harness from the headlight.......he was using the pick and I was pulling on the harness and eventually we got it. Definitely a pain! The other thing I found out was there is not enough lead wire to plug the harness into the new 06 lamp assembly I was putting in my 04 Coupe. What we did was to slide the plug on the headlamp assembly off the post that it is sitting on so we would have enough wire length to plug them together. Hope that helps you out.
Old Nov 14, 2008 | 05:38 PM
  #87
YT35's Avatar
thanks, but i still cant get it lol, did u pick it from under the harness?
Old Nov 14, 2008 | 05:39 PM
  #88
YT35's Avatar
i dont even see the clips
Old Nov 14, 2008 | 05:41 PM
  #89
Yes. He had to use the pick underneath the harness. The clip is small and all the plastic being black doesn't help either. You definitely need to use a flashlight and it will still be some feeling around that you need to do.
Old Nov 14, 2008 | 06:07 PM
  #90
YT35's Avatar
i see the clip nowq but do u pull it or press it down?
