G35 Coupe Headlight Removal Guide (3 Simple Steps)
Old Oct 29, 2012 | 12:08 AM
  #196
nbarkins's Avatar
Originally Posted by importroller
Now, if only i can find somewhere to buy a clear lens for the amber that is in the OEM (no projector) housings.
go to any hardware store, lowes,home depot,ace,etc etc. Buy a sheet of plexi glass, cut it out using a stencil of the amber one cut out of paper, wam bam!! now u have ur own.(and save crazy amounts of money! they make diff color plexi glass, so u can make a "custom" look if you wish. u can also do this with the compass/temperature display, to get rid of the ugly orange color and plastic!
Old Oct 29, 2012 | 01:53 AM
  #197
SAMzG35's Avatar
G35
What the man above said, plexi glass will do the job. You will also need a silver coated amber turn signal bulb or SwitchBack LED bulb. other wise it'll always have that amber look to it
Also in 03-05 housing you can use any projector 2.5" lens
Originally Posted by nbarkins
My 06 projectors don't have a bulb or even a bulb space, in the cealrance strip why would that be?
Clearance strip is only in 03-05 reflector type housing. 06+ projector headlights dont have them
Originally Posted by Jwms
Do you have to open the case to Chang the bulbs? How do you re-seal them?
No you dont, two ways to change bulbs, either from wheels wells or by removing front bumper. Once you have access to the back of the headlights there will be a cap behind each bulb, Twist off and replace, Pretty straight forward.
However to install CCFL tubes, rings or LEDs inside the housing you do have to open the housing.
Old Oct 29, 2012 | 03:36 PM
  #198
nbarkins's Avatar
im not sure why i asked that question about the clearance light the way i did, but ty for the response
Old Jun 29, 2014 | 11:36 AM
  #199
PLENUMCOUPE's Avatar
Hhh
Old Aug 19, 2014 | 04:44 PM
  #200
sdwhatley's Avatar
I'm planning to take off the bumper and remove the headlights today but for some reason the images no longer show up with the original DIY write-up. Any ideas/alternative instructions?
Old Jun 26, 2015 | 11:47 AM
  #201
Patrick Bovee's Avatar
Having the same problem. I have a Oracle halo kit for my 06 coupe. I'm trying to find someone to install them. He asked if I can take the headlights off myself then give it to him. Is there anyway to get those pictures?
Old Jun 26, 2015 | 01:00 PM
  #202
hdmark's Avatar
its pretty easy, just drop the front bumper and then there are 3 or 4 bolts holding the headlights in. remove the bolts, pull the headlight up a little, and disconnect the wire harness
Old Feb 1, 2016 | 05:51 PM
  #203
Shawn Tooley's Avatar
Why can't I see pictures in the post?
New to the forum... Why can't I see the pictures in the post?
Old Feb 1, 2016 | 05:58 PM
  #204
JOKER's Avatar
CLUB MODERATOR
because it's from one hundred million years ago and pictures went extinct with dinosaurs.
Old Feb 1, 2016 | 06:55 PM
  #205
Not asking for a "VHS" or "Super8" of the operation
But pictures (e.g. jpg, etc) are still fairly standard. Are you saying that because the original post was so long ago, pictures have been removed or deleted? Do I need to upgrade to premium in order to see pics?
Old Feb 2, 2016 | 12:23 AM
  #206
JOKER's Avatar
CLUB MODERATOR
Original poster must have removed the picture from their original hosting location. So they are no longer shown.
Old Feb 2, 2016 | 08:56 AM
  #207
Urbanengineer's Avatar
This is why people should use the built in photo wizard to house photos for DIY's and such.
Old Feb 2, 2016 | 11:16 AM
  #208
JOKER's Avatar
CLUB MODERATOR
back in those days the system was slightly more retarder than it is now. So hosting pictures on driver was not always an option.
Old Feb 2, 2016 | 12:01 PM
  #209
SAMzG35's Avatar
G35
Ahahaha
Old Feb 3, 2016 | 12:06 PM
  #210
That's true, there are other threads about this but I could get detailed photos of this procedure when I pull a g apart next month.
