Bulbs for Corner and License Plate
Old Apr 3, 2006 | 06:40 PM
ChOy BoY's Avatar
hey i just did my clear corners today, just wanted to know everyones suggestions on what type of bulb i should get for the corners and where to get it from, itd also be a big help if you could post pics of what they look like. Also, what kind of bulbs the license plate light uses and if it's difficult to install? thanks everyone
Old Apr 3, 2006 | 06:51 PM
Mike_Deezy's Avatar
Not sure how hard it is to change the license plate bulbs, but it should be pretty easy I'm sure. The plate lights on the new Lexus GS looks really nice. I would love to have those. Anyone know what kind of bulbs those are?
Old Apr 3, 2006 | 07:14 PM
Machine Head's Avatar
194/168 wedge bulb is the license plate. i suggest going with a LED white bulb.
Old Apr 3, 2006 | 09:35 PM
ChOy BoY's Avatar
so then basically they're the same exact bulbs..both 194's?
Old Apr 3, 2006 | 10:30 PM
mr_ecktid's Avatar
so do you guys just go to autozone or some place for the corner bulbs?
Old Apr 3, 2006 | 11:02 PM
Derek S's Avatar
never buy aftermarket bulbs from autozone or pepboys they are JUNK. get it online.
Old Apr 3, 2006 | 11:53 PM
ChOy BoY's Avatar
do u hav any suggestions on wat site to use?
Old Apr 3, 2006 | 11:55 PM
dream_G35's Avatar
same question.....i want license plate bulb.
Old Apr 4, 2006 | 01:40 PM
Derek S's Avatar
this is one but the best thing to do is to find out what brand of bulb and what size you want and just get it off ebay.
http://www.cardomain.com/shoptype/Ex...lacement+Bulbs
http://search.ebay.com/search/search...rclo=&saprchi=
o and if you get it from ebay dont get BESTHONGKONG i got a few 194 bulbs from them and they were not bright at all.
Old Apr 4, 2006 | 03:49 PM
rltaylor's Avatar
I'm running the PIAA LED's in both my corners and license plate. The license plate bulbs (yes there are two) are easy to change. If you look up above the license plate there are two plastic holders. Each with a clip on the right side. Just push in the clip and pull the plastic holder down, swap out the bulb up push it back in the hole until the clip snaps into place. Both holders are set up the same with the clip in the same spot. Hope this helps.
RT
Old Apr 4, 2006 | 04:14 PM
ChOy BoY's Avatar
alrite so 194 is the size of the bulb for the corners..is it the same for the license plate bulbs?
Old Apr 4, 2006 | 04:38 PM
charog's Avatar
Lexus Bulbs
So does anyone know what kind of bulbs are being used in the LEXUS GS license plates.
Old Apr 4, 2006 | 09:35 PM
Derek S's Avatar
if they are 194 like ours then you can just go to the lexus dealer and buy them.
Old Apr 16, 2006 | 02:26 PM
Cloud_35's Avatar
Is this the LED you guys are using for the corner bulbs?
http://www.cardomain.com/item/PIA19409
If not, then what size am I to use?
Old Apr 16, 2006 | 03:26 PM
TheTrance's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8047155996
