Top Secret V35 (G35) Tail Lights
Old Jul 26, 2006 | 02:44 PM
  #61
RugRatCoupe's Avatar
RugRatCoupe
20 Year Member
Originally Posted by afr0puff
Hey, did you ever get the cones I sent you a while back? Wondering how your project is going.
NO!!! I didn't know you sent them
Just about to start back on the Taillights again.
Thinking about going a different direction w/Four of these multi LED sealed Taillight/Brake lamps from American Superlite Inc. That way all will be the same brightness. Only problem is they only offer them in 4" size.
Another site I'm looking at that has custom mounted LED's is: http://www.lambertenterprises.com/
Old Aug 15, 2006 | 11:50 AM
  #62
RugRatCoupe
20 Year Member
bump.....
Old Mar 8, 2007 | 11:19 AM
  #63
cochinogato's Avatar
i know im all 7months late and all- but anymore updates on whatever happen to the tails you all were doing? anything?
Old Dec 30, 2008 | 04:50 PM
  #64
jlo0109's Avatar
+1 INterested if anyone has finish this project.
Old Jun 6, 2010 | 08:35 PM
  #65
Ryuu's Avatar
Can anyone put a DIY for dremeling open the light? And how can you power the tail lights at home? As in when you are working on them, and want to check without hooking up to the car. I take it its some kind of battery pack. Thanks!
Old Jun 7, 2010 | 03:55 PM
  #66
MrMarc's Avatar
https://g35driver.com/forums/1136740-post35.html
And how can you power the tail lights at home? I take it its some kind of battery pack. Thanks!
All you need is a 12v power source. A lot of people, including myself, use spare PSU's taken from old/dead computers.
I'm curious about the status of this mod as well. Debating on doing this to a set of JDM tails.
Old Jun 7, 2010 | 04:47 PM
  #67
juan350gt's Avatar
sincity makes those they are on youtube.
Old Jun 7, 2010 | 05:25 PM
  #68
MrMarc's Avatar
I think the consensus here is that the vendors are selling them at prices that are higher than most are willing to pay for this type of mod so we're looking to see what's involved to do it ourselves.
Old Jun 7, 2010 | 05:35 PM
  #69
Ryuu's Avatar
Thanks MrMarc!
12v psu from old computers sounds like a good idea. Which wires from the harness should I connect to the PSU?
Old Jan 6, 2012 | 11:44 AM
  #70
G35thrilla's Avatar
My aftermarket leds are wired up in parallel and im not sure where i should tie them into the existing wiring harness to have both led rings light up all the time. Do i just tie them into the postive and negative wires that led to the plug that is plugged into the stock led circuit board???
thanks in advance
Old Jan 11, 2012 | 11:49 AM
  #71
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
The stock LED circuit board has three wires. Pos for taillight, pos for brake, and neg wire. I assume that you'd want the aftermarket LEDs to also light up when brakes are applied?
Connector on the left. You can see the three prongs for the wires. This was the first set that I made.
This is the second. Don't have time anymore to work on such things, but as mentioned in this thread, opening up the lights wasn't fun.
Old Jan 11, 2012 | 12:12 PM
  #72
2004v35's Avatar
wow looks sick!
Old Jan 11, 2012 | 12:39 PM
  #73
G35thrilla's Avatar
Well the way I have it wired and tested right now I have the aftermart leds tied into the tailights only.
How would I need to wire if I wanted to use them as a dual purpose for tails and brake light?
I hope I'm making sense EK
Old Jan 11, 2012 | 02:06 PM
  #74
E_K's Avatar
E_K
What kind of aftermarket LEDs are you using? I'm not sure how you currently have things wired. Any pics?
The stock setup uses the circuit board to create two levels of brightness by using two different levels of resistance. I wired extra LEDs from the wires coming off the circuit board from the white connectors.
Ludz
Lights
Mar 28, 2016 02:06 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
