The M-Spot For General discussion of the M35/M45
creating a Custom Weapon*R Secret Weapon intake + CAI
Old Mar 3, 2008 | 02:43 PM
turboale's Avatar
One big motha...
The VDC Off button is located down low to the left of the steering wheel. There are two "tiers" of buttons down there, its easy to not see them. I believe its next to the trunk release but I could be wrong. Its down there either way...
Old Mar 3, 2008 | 03:24 PM
giddyup69's Avatar
hope u get another chance to test it. i'm interested to see the results... looks like a great product.
Attached Thumbnails creating a Custom Weapon*R Secret Weapon intake + CAI-untitled-1.jpg
Old Mar 3, 2008 | 03:36 PM
SlooberTooth's Avatar
I wouldnt be suprised if there was some low to midrange HP and Torque lose. CAI usually make the car run to lean and w/o tunning the car, the ecu will try to compensate this by adjusting the timing which = power loss. You should dyno the car and then dyno it again after tunning it.
Old Mar 4, 2008 | 01:49 PM
bruddahmanmatt's Avatar
Originally Posted by WeaponR
we ran into some problems with the M45 on the dyno. Apparently, there is no VDC off button...
What the heck are you talking about? The VDC off button is in the same place it's always been since '03. It's below the far left A/C vent, to the left of the steering wheel right by your left knee.
Old Mar 4, 2008 | 02:30 PM
ballisticus's Avatar
When you get the Weapon R "filter" unit, take a good look at the area between the plastic base plate and the foam media.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
HellaG35
Intake & Exhaust
Sep 8, 2015 10:02 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
