The M-Spot For General discussion of the M35/M45
automatic window wont go up
Old Oct 19, 2008 | 03:53 PM
BIGTONE's Avatar
my driver side window wont go up with the automatic. its goes up but just not auto. all the other windows roll up and down with auto expect the driver side. is there maybe a fuse blown or what do you think?
Tony
Old Oct 19, 2008 | 05:13 PM
bruddahmanmatt's Avatar
Tony
Make sure the window is rolled all the way up. Push the switch all the way down (second click) and hold it for about 5 seconds after the window has been rolled all the way down. Then lift the switch all the way up (second click) and hold the button for about 5 seconds after the window has been rolled all the way up. This resets the auto up/down feature. Chee hoo.
Old Oct 19, 2008 | 06:26 PM
BIGTONE's Avatar
That worked!! Thank you very much!!!!
Old Oct 19, 2008 | 06:58 PM
No prob.
Old Oct 21, 2008 | 05:43 PM
Rizzagt22's Avatar
Its happened 10 times on my 08' G35 sedan. Expect for it to not get fixed by just re-seting via holding the switch up and down for the 5 second intervals. Let me know if the problem continues within the next 3 weeks.
Old Oct 21, 2008 | 07:19 PM
BIGTONE's Avatar
ok I'll keep you posted. Thanks!
Old Oct 22, 2008 | 01:59 PM
jmendoza7's Avatar
I have to this after the few car shows I did and it gets fixed and never comes back until you take the battery out again. This also happens to my sunroof. Same procedure to fix the sunroof.
Old Oct 22, 2008 | 10:02 PM
Williamr615's Avatar
I have a similar problem but with my driver side automatic window. Its lilke of track and I dont know if I should even try to take the door apart or to take it in.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
