AC/Radio control modification
Old Aug 6, 2015 | 04:36 PM
WillisFL's Avatar
I thought I had previously found a resource or at least some pics of how this was done. I don't recall exactly as I saved it to my bookmarks to look at a later date. I've since lost those bookmarks (that's another story). I can't seem to find it via searching on here or on google.
I believe someone had modified or cut the circuit board for the radio/ac controls to retain the factory ac controls (not JDM controls) but in a manner that removed the factory stereo but kept the ac controls. Then modifying the console to fit a double din, LCD screen, etc. I could have sworn I had a link to this procedure.
I work on electronics for a living so the soldering and adding/removing of components wouldn't be an issue. I was just curious if this had been done before or if I just totally conjured this up in my mine...haha. The only reason I'd be interested in going this route is because I'd be doing a custom setup and if I can do this without purchasing the JDM controls or a dash kit I could use those savings towards other goodies in the install.
If anyone can steer me in the right direction it would be appreciated.
Old Jan 5, 2016 | 01:13 AM
DAvid Brewer's Avatar
bump
Old Dec 29, 2016 | 08:56 AM
THE MUFFIN MAN's Avatar
Ok, there must be several different harnesses on the G models, because I can't find an exact one like your last pic, or one like the one that came with the instructions. I did find one with the wires in the same pins as the instructions, so I would think this is the correct harness? First pic is the instructions, second pic is the harness in my car.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
markbilo
Sep 30, 2015 01:33 AM
