airbag llight
Old Mar 3, 2008 | 07:13 PM
jdmv35_99's Avatar
Old Mar 3, 2008 | 07:17 PM
rookie's Avatar
Dam it, Zack posted while I was doing screen captures!?!?@?@#?#?$#%
Old Mar 3, 2008 | 07:19 PM
jdmv35_99's Avatar
lol thanks to you too rookie.. i also need help on reseting my power windo motors how can i do that??
Old Mar 3, 2008 | 07:29 PM
rookie's Avatar
I was just playin. Found this. https://g35driver.com/forums/showpos...6&postcount=11
Old Mar 7, 2008 | 06:51 PM
esfoad's Avatar
Originally Posted by zackt69
Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 secs, and then turn off, and then start to flash.
To reset the light, you must turn the key to on, watch the airbag light stay solid for 5-7 secs and as soon as the airbag light turns off, turn the key to the off position (you have to turn the key to off before the airbag light starts to flash, or you must start over). You need to repeat this 5 times. Try to start the car, and hopefully the light will be reset.
That's why I love this forum. Most every time the answer is here. It was again today. I did the reset procedure and the light is now off. I will check all connections under the seats but the problem started on its own, no modifications or anything. In fact from one work day to the next where the car stays put in the driveway. Anyway, thanks to all for the continued help.
Old Mar 7, 2008 | 10:04 PM
bluecrown's Avatar
Nice...
I am a newbie and this site rocks! thanks for the fix guys!
Old Mar 30, 2008 | 04:06 PM
jesse's Avatar
i know this is a bit of a big bump, just wanted to say thanks, worked like a charm
Old Apr 3, 2008 | 09:22 AM
iceman2011's Avatar
I just got it ths SRS light yesterday. I am going go out and test this in a bit.
Old Apr 16, 2008 | 01:19 PM
selyorsoul2roll's Avatar
Thanks man. i had that light on forever and this worked great!
Old Apr 16, 2008 | 08:25 PM
shottaj's Avatar
Parts
I Brought A 907 Salvage G35 Coupe, And I Need The Anti Freeze/ Window Washer Reservoir, A Hook Up On Dealer Black Airbags Driver And Passenger, Front Seat Belts And Dashboard. Please Someone Help Me. Shotta J *(347) 524-8687
Old Apr 23, 2008 | 07:22 PM
Skyline GT-R's Avatar
Thank god for the G35 community. After having read the posts about flashing airbag icon, I was having the same issue and it started earlier this month. Dealership wanted me to take it back in for analysis, and I knew they were going to screw me.
To the member who posted the turn the ignition to the on/off position 5 times before the airbag icon began to flash. This worked for me. It reset and NO MORE FLASHING AIRBAG ICON!!!!!!
I can't say enough to ALL the DIY-members who have have posted great videos and photos with instructions. This has saved many members $$$$$, including myself.
THANK YOU ALL!!!!!
Old May 18, 2008 | 01:42 AM
earth0's Avatar
Holy..Moly!!! Thanks a bunch!!! Very Appreciate all your help.
I thought i have to take my 08 G35X to the Dealer already.
It's all work with just one set up.Two Thums Up!!!!!
Old May 18, 2008 | 01:45 AM
earth0's Avatar
Originally Posted by rookie
Here's the diagnostic mode from the service manual. It's out of the 05, but I looked in the 03 and it said the same sequence.
Warning lamp examples.
This has worked for me in the past when something was left disconnected.
Thank you very much!!! Superb!!!!!! AAA++
You the Best!! God bless!!! What can i said.Thx..man
Old Apr 8, 2009 | 03:32 PM
Mustang5L5's Avatar
Did a search. This worked like a charm for me.
However, a few weeks later the light came back for me.
My passenger air bag disabling switch hasn't been working correctly, so i always suspected it was that. So in it goes for service
Old Dec 19, 2009 | 07:53 PM
  #30
logg's Avatar
Bought my first G 2 days ago and have already used the info from this forum for the flashing supplemental fix and the clock led fix. Great forum and great info. Not to mention the Honda Inca pearl touch up for the Brembos
Thank you
