taking apart 3 piece rims
Old Mar 29, 2008 | 01:26 PM
fabulustt7's Avatar
so i found a place to rechrome my lip but they want me to take apart my maya mrs and give them just the lip to fix. now how do i do that or who can i go to fo that?
Old Mar 29, 2008 | 01:32 PM
Johnmikins's Avatar
If you do it make sure you take of the bolts in a star like pattern...one on top, one on the bottom, back up top, back down to the bottom...and when you put it back on make sure you have the correct torque specs for the bolt and nut...
Old Mar 29, 2008 | 03:15 PM
fabulustt7's Avatar
damn im going to mess up my wheel aren't I??
Old Mar 30, 2008 | 12:58 PM
Locksmith's Avatar
Probably...
Old Apr 3, 2008 | 04:31 PM
broke_as_ajoke's Avatar
yea it sounds like it.. make sure u know what u are doing..
Old Apr 3, 2008 | 04:46 PM
GreenGoblin's Avatar
The goblin resurrection
if you have the right tools its not hard at all, if you dont have a torque wrench and sockets dont bother trying
Old Apr 3, 2008 | 04:48 PM
redlude97's Avatar
depending on the way the wheel was put together, you will have to also reseal the 2 halves of the barrels with some type of sealant. This should really be left up to a wheel shop to do
Old Apr 6, 2008 | 02:21 PM
Sylvan lake V35's Avatar
Each 1/2 of the wheel should be marked so they go together the same spot they came apart from. Its hard to explain but each lip should stay with the same inner barrel and the lip should be fitted to the same orentation it came off like the lip shouldnt be off a 1/4 turn from the way it came thus the reason for marking it I hope that makes sence. I know its something I never thought of until talking to a wheel repair shop.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
