20"x8.5" - +35mm Offset - 6.065in Backspacing
Old Oct 2, 2008 | 11:25 PM
DMcBrideBoston's Avatar
Any fitment issues/rubbing for a G35 Sedan?
Also what size tires would you recommend?
Thank you
DJ
Old Oct 9, 2008 | 12:09 PM
az1anbeethoven's Avatar
20x8.5 all around?? do you have an X? to answer your question, simply...
245/35/20...no rubbing with 350z drop...no fender rolling required...
Old Oct 9, 2008 | 01:08 PM
SIN3's Avatar
8.5 rears??? eeekk
go bigger man.. at least a 10.. roll the fender if you have too.
Old Oct 9, 2008 | 02:32 PM
ttrank's Avatar
Grocery getter
You can run an 8.5 on the rear to keep the same tire size all around but I would get some spacers to help fill in the gap a little more.
Old Oct 11, 2008 | 07:11 AM
No I don't have an X
Originally Posted by SIN3
8.5 rears??? eeekk
20x8.5 up front with 245/35/20
20x10 in the back with 275/35/20
Is this what you'd recommend?
I have to look into what rolling the fenders is, I have never done this or seen a write up before.
Old Oct 22, 2008 | 04:14 PM
SIN3's Avatar
back is nice but what offset with that width? 40-50s at least.
Old Oct 22, 2008 | 11:43 PM
would you recommend 255's in the rear instead of 275's?
Offset on rims is +35, not 40-50's, so i don't really know what you are asking or saying i should do.
thank you
DJ
Old Oct 23, 2008 | 12:40 AM
coolguy8157's Avatar
20x8.5 offset +35 front with 245/35/20
20x10 offset +43 back with 275/30/20
ideal for you...if you go with 20's ..I would think
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
