stance coil instal
Old 05-07-2009 | 08:20 PM
MikeGrote's Avatar
stance coil instal
i got one in (pictured) but i forgot to get the sleeve for my spc upper arm so ill have to get that tomorrow. ill do the other front coil tonight and then the a arms and rear coils and camber arm tomorrow. just thought i would throw a couple pictures up on here.
spc, front and rear
stance gr+ pro coils
front fender gap (before install)
rear fender gap (before install)
one coil on
i will say the upper arms come off really easy and that makes getting the coils in and out of there much easier.
edit: i set the front coil to 1" lower than stock, so after the spring settles some, i should be about 1.25"-1.5" lower than stock
Old 05-08-2009 | 12:03 AM
sK4UF3L's Avatar
how are you liking the stance coils?
i have the same set up and seems to ride pretty stiff in the rear. Do you know if there is anyway to make the rear softer? i know the fronts you just turn the *****...
Old 05-08-2009 | 12:56 AM
Blackmouf's Avatar
They look hot. How much do coils usually drop more after settling?
Old 05-08-2009 | 01:17 AM
MikeGrote's Avatar
the rears have the same adjustment **** as the fronts do, but when the coils are installed, its pretty much impossible to get to it. so the solution to that is, if you look at my second picture, there are extensions you can buy. they are right above the rear coils in that picture
Old 05-08-2009 | 01:19 AM
MikeGrote's Avatar
from what ive heard, 1/4 to 1/2 inch
Old 05-08-2009 | 01:29 AM
MikeGrote's Avatar
both fronts are almost done, i just need to pick up that sleeve tomorrow and throw them on. i got the arms and coils on both sides. along with the 15mm spacers for the front. i got 20mm spacers waiting to go on the rear. i wish there was a way to adjust the height without removing the whole coil, but i dont see how thats possible....
old vs new
drivers side
passenger side
Old 05-08-2009 | 01:45 AM
MikeGrote's Avatar
ah shyt, i forgot to measure my fender height before i took it all apart. anyone have a front fender height on a stock g with the sport suspension package?
Old 05-08-2009 | 05:34 PM
Blackmouf's Avatar
You have to take the coil off everytime you want to adjust the height? Wow that's lame.
Getting the right height must take forever.
Also, what sleeve are you referring to that you need to pick up?
Old 05-09-2009 | 04:41 AM
MikeGrote's Avatar
my mistake, you can adjust the height and dampening without taking the coils off.
the sleeve that sits in the top part of the knuckle. the shaft of the a-arm goes through the sleeve. turns out, none of the nissan or infiniti parts departments here keep those in stock, so i loaned a pickle fork kit from the auto store and popped them off real quick. they came off prety easy, im glad i didnt buy new ones.
i really need to get my fenders rolled QUICK
Old 05-09-2009 | 04:52 AM
MikeGrote's Avatar
heres my fender gaps. rear was a pita cause of the extension not wanting to feed through where i wanted it but after a couple hours on that alone, i finally got it.
front
rear (i need to have my fenders rolled asap)
Old 05-09-2009 | 05:08 AM
xx7sephiroth7xx's Avatar
G
Looking good man!
Congrats on all those new parts!
Glad it all worked out.
MikeGrote's Avatar
hahahaha, didnt even make it out of my apartment complex. scraped on half of the speedbumps and my rear tires are rubbing on the fender. ill prob raise the rear to match the front and see how that goes tomorrow
Old 05-09-2009 | 10:40 PM
MikeGrote's Avatar
im still scraping on something just behind the front wheels when i go over some speed bumps, so i need to figure out what that low point is and make sure its nothing too important. if its just frame, ill leave it at this height. i love the way it looks. pics:
Old 05-09-2009 | 10:46 PM
O HELLA OEM's Avatar
looks good
Old 05-09-2009 | 11:14 PM
dvsmeth0dz's Avatar
+1. i like how it sits.
Quick Reply: stance coil instal
