Who's rollin with taller rubber in the rear?
Old Aug 26, 2009 | 03:04 AM
  #46
redlude97's Avatar
Originally Posted by JOKER
not always.
due to the tall sidewall the weight of the car is able to shift left and right in the turn, therefor causes wheel to lose traction.
the sidewall height change is only 4mm
Old Aug 26, 2009 | 03:38 AM
  #47
binder's Avatar
is this for real?
so you think not only can you "feel" 5mm of height difference when getting out of a car you also gained 15hp from a synthetic oil?
You do know that these cars come with synthetic oil in them from the factory right? At least that's what they put in the car at my dealership.
I have 18x9 front and 18x10 rear. 245/45 front and 305/35 rear. The fronts are stretched enough on mine that i woudn't go any skinnier. You have 225's on them and you want to try to get a 205 on a 9" wide rim? Then you are going to "drift" it and stress the sidewall and hope that it doesn't break the bead?
Oh ya, just fyi, you have to disable the abs if you're going to do any real drifting because our cars will lock up the wheels if you push on the brake when the rear is spinnging (yes, even with VDC off). So i doubt you're really "drifting" since we know you aren't using the rear brake.
Old Aug 26, 2009 | 11:14 AM
  #48
JOKER's Avatar
CLUB MODERATOR
little more then that and at high speeds it's enough to \ _\ shift the tire and lose traction.
Old Aug 26, 2009 | 12:48 PM
  #49
parhamm1's Avatar
This thread got funny. I thought I was going crazy being the only one questioning the OP...
Old Aug 26, 2009 | 01:06 PM
  #50
pythonjosh's Avatar
Originally Posted by binder
is this for real?
I know my car didn't have synthetic when I got it. Because of the gains from changing it to synthetic. That's the only time I've changed the oil in the car. After the oil change, yes just an oil change, the gains were huge. Do you think oil has no part in the amount of power the engine can put out?
Not only do I notice the ride height difference while driving, my undercarriage notices it as well.
Old Aug 26, 2009 | 01:41 PM
  #51
SoloG35-719's Avatar
Idk about the whole gain 15+hp with an oil change man....
Old Aug 26, 2009 | 01:43 PM
  #52
pythonjosh's Avatar
I guess it just means the previous owner of my G put some ****ty *** oil in it.
Old Aug 26, 2009 | 01:46 PM
  #53
I didnt even gain 15hp with a new MAP on my G.
Old Aug 26, 2009 | 01:57 PM
  #54
JOKER's Avatar
CLUB MODERATOR
put some of that oil on that map then see what happens.
Old Aug 26, 2009 | 02:04 PM
  #55
redlude97's Avatar
How is it more than that? You increase the width 10mm over stock, the increase in height is 40% of the increase in width=4mm sidewall increase. Did you run that exact rear size with a 225/40/19 on the front so that you can attribute the oversteer to the increased tire height and not the increase in width on the front?
Old Aug 26, 2009 | 02:35 PM
  #56
JOKER's Avatar
CLUB MODERATOR
I ran 245/40/19 and 255/40/19 on the rear while front remained 245/35/19
And with 255/40/19 I get more oversteer then I did with stock set up or previous set up.
as far as the difference I thought you were talking about my front and rear tires.
Old Aug 26, 2009 | 04:34 PM
  #57
got_boost99's Avatar
Don't you guys know that changing the oil adds HP? Didn't you guys play Gran Turismo? LMAO!!!
Op: How do you know you gain 15HP? You dyno'd the car previous to and post oil change? Or it was a butt dyno?
Old Aug 26, 2009 | 05:34 PM
  #58
blaccG35's Avatar
haha i dont think you need to lower is man look at your front bumper...hahaha jks but it does look kinda off IMO
Old Aug 28, 2009 | 10:06 PM
  #59
binder's Avatar
haha, so the high school challenges my knowledge on motors? how many 16k rpm race bikes have you build? During the summer months i do about 3 engines a week for my racers.
I know about oil and there is no oil in the world htat will just instantly add 15hp to your engine. Well, i guess if you had sand in your previous oil then ya, it might, but other than that, no.
Have you even seen a dyno in person?
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
derres
Aug 28, 2015 03:27 PM
TreeFiddy
Aug 10, 2015 06:50 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
