I need tire size recommendations..
Hey guys I have Work Emotions CR-Kai's in 18x8.5+42 and the front are 18x7.5+48and their pretty high offset. Don't ask haha! I got these rims for dirt cheap. I plan to get spacers, what size spacers do you guys recommend? And what size tires? I'm aiming for a flush look but not aggressive to where I can't even drive my car around anymore. I've been doing research but I have been hearing mixed reviews. Right now I believe I have 225/45/18's? For some odd reason, my rims look so small for my car. My stock 17's looked bigger!
I need your help guys!
do you have a coupe or sedan?
either way my friend, you have pretty small wheels.
even my 25mm spacer on my stock 18's with +30 offset isn't quite flush. your wheels will have problems being flush imo.
really? dammit, i have a sedan.
18x7.5 + 42 in the front
18x8.5 + 48 in the back
is there anything wrong running large spacers? i am down to go up to an inch if I have too.
OP-Sedan or coupe?
If the spacer is installed correctly with correct hub centric sizing and extended lugs, you should have no issues.
it'll be flush with some spacers, what thickness i don't know.
