My Dual Ring Tail Project: Sedan Tail Implant
Old Mar 4, 2010 | 04:26 PM
jayk's Avatar
Ever since the G35 Sedans started having the Dual Rings (skyline look) and then the G37s came out... i have wanted to Duplicate this since Nissan/INFINITI forgot about the G35 COUPES!
I finally got my 06 USDM Tails so im going to attempt this with my 03 Tails first then try it on my new Tails as my Final Project. I am NOT an Electrician/technician or in any field relating to electrical so i am going to try to keep soldering to a minimal as well as keeping everything OEM and pretty much retain the inner LED cluster. Im not trying to do anything fancy.
Ill try to update after every session i work on these, but due to my new work schedule ill probably only have a few hours of time a day for this project.
Got a few tips from E_K, but instead of just implanting the smaller ring, I am going to put both Sedan Rings since the 03 LEDs are rather dull compared to the Sedan's (see picture 1)
Ive already come up with an issue that im not quite sure on what to do yet. since the Sedan Rings are in a Oo oO sequence with the larger Ring on the outside... and the Coupe has a oO Oo, my issue is that if i implant the Sedan Rings but just switching the location, the turn signal bulb (with is in the center of the Larger Ring) would be on the Inner Circle instead of the outer. hmmmm.. i dont really want to fabricate the outer Ring to be the blinker. well see.. ill figure it out.
so far i purchased a Drivers side 07+ Sedan Tail from a local guy (i only have this drivers side so if you know if anyone might have a Passenger side.. let me know. lol. https://g35driver.com/forums/showthr...ferrerid=13080)
Sedan 07+ Tails Next to 03 Coupe Tails
Sedan Donor
Donor LEDs Cut out next to Coupe Tails
Testing LEDs
Sedan Opened up
For reference... my Coupe Reverse Light has been accumulating mositure inside recently. i dont really know why.
Ok figured out how the moisture was getting in. ill fill that in later.
Opened up 03 Coupe Tails
Cut out Sedan Donor next to Coupe Tails
Coupe Outer Ring Cut out
Test Fitting Outer Ring
Test Fitting Outer Ring: Rear Shot
Lens for the Sedan is too big. i need to figure out how to make this fit....
I might have to sacrifice my Side light to make the LED cluster light up. oh well.
Old Mar 4, 2010 | 04:32 PM
OBGrob's Avatar
damn bro from when i left your house to now, youve done a lot of work... in like 2 hours? geez, good job though.
Old Mar 4, 2010 | 04:34 PM
jayk's Avatar
haha yeah i gtg to work now.
Old Mar 4, 2010 | 04:37 PM
antknee's Avatar
good luck pacman,.. nice project
Old Mar 4, 2010 | 04:50 PM
VictoriousG's Avatar
Damn that looks complicated gl jayk youll need it ha so far so good though.
Old Mar 4, 2010 | 04:55 PM
JOKER's Avatar
CLUB MODERATOR
Damn you just butchered the crap out of those light.
Hopefully it comes out looking nice.
Old Mar 4, 2010 | 05:00 PM
jayk's Avatar
if you are talking about the SEDAN tails, then YES. i didnt really take my time and they were more for practice.
but the Coupe lights are cut pretty clean. i cut them at a different angle. There will be some torn edges from the Dremel, you cant avoid that. ill clean that up later with a buffer or just peel them off. all that will be sealed up. ill take a better picture to show the cut tomorrow.
Old Mar 4, 2010 | 05:08 PM
ShanesG's Avatar
Good stuff, in for final results!!!
Old Mar 4, 2010 | 05:09 PM
Law to the Rence's Avatar
legit! bump for this homeboy right here, can't wait to see results
Old Mar 4, 2010 | 05:14 PM
The Stimulation's Avatar
Cant wait to see final results. Keep up the nifty work.
Old Mar 4, 2010 | 05:58 PM
HenryLee's Avatar
Wow looks sick!
Old Mar 4, 2010 | 06:02 PM
TofuProductions's Avatar
Nice looks just like my tails almost
Keep up the good work!
Old Mar 4, 2010 | 06:12 PM
jayk's Avatar
^whoa! Nice!
What did you do about the turn signal/blinker?
Old Mar 4, 2010 | 06:15 PM
it's still there in it's stock location. there's just some led high intensity led bulb in there.
Only difference is the outer ring around is now led as you see in the pictures.
Old Mar 4, 2010 | 06:19 PM
Ghayes23's Avatar
Nice work so far! I'm gonna keep an eye on this.
