04 Retrofitted Mini D2S-G37-R Shroud, Clearance Strip Delete
Old Mar 5, 2012 | 11:08 PM
Frankieg35's Avatar
Looks great!!
Old Mar 7, 2012 | 12:17 AM
TemjinX2's Avatar
Originally Posted by ss284
Looks Great!!! Bet your Quads are insane for night time driving!
i usually just use the top fx-r's and some times i use the bottom tsx's with the fx-r's when i'm alone on the road in and the area that isn't well lit.
The extra beam width of the tsx projectors are pretty nice.
Right now i'm using 55watt ballasts on the fx-r and the oem ballasts on the tsx's. Some times when a driver pisses me off at night, pretty much can light up there life with both quads on and the fx-r high shields open...
I get a good amount of blue at the cut off...its hard to see the purple because of all the haze from my head light covers...i tried to sand off as much as i can but it still kills a lot of the color.
Old Mar 7, 2012 | 12:24 AM
Beebo's Avatar
OP great work. if you can post some night time pics
Old May 22, 2012 | 02:49 AM
EDGAR's Avatar
Nice retrofit!! did you have any problems with your ballast (flickering) at all? i did mine but i don't know how to fix the flickering, i think it has something to do with the yellow cable that goes to the bulb connector, do you have any tips?
Old May 22, 2012 | 02:55 AM
EDGAR's Avatar
here are some pics of my
retrofit
Old May 22, 2012 | 02:56 AM
Mr. Brett's Avatar
Flickering HID bulbs can result from three things:
Bad salts in the bulb
Improper connection/weak electrical source
Non-digital ballasts
I'd suggest checking all of your connections first, especially your grounds. Did you run a seperate power wire and relays for your HIDs, or did you use the OE wires?
Also, are you running stock ballasts or aftermarket? There are a lot of things that can go wrong with HIDs. Telling us a little more info about your setup can help a lot.
Old May 22, 2012 | 03:03 AM
EDGAR's Avatar
i used the stock wires and ballast
Old May 22, 2012 | 03:14 AM
ss284's Avatar
hmm cannot remember the cabling will need more info, so your using OEM ballasts?
Old May 22, 2012 | 03:18 AM
ss284's Avatar
oh whoops just read that, nevermind.
I dont have a flcikering issue, only issue I have was with my poor sealant skills, got a little condesation and had to re clamp it, but never affected the wireing...
im sorry I cant remember the specific wireing. Was all plug and play for me besides the cutting and drilling for mounting the projectors.
May need a new Ballast? Could be a number of things
Old May 22, 2012 | 12:06 PM
Mr. Brett's Avatar
Sounds like bad salts in the bulbs, then. Where did you buy the bulbs from? Cheap bulbs will do this a LOT.
Old May 22, 2012 | 12:55 PM
ss284's Avatar
Theretrofitsource.com
Absolutely no issues with any of their products
Bought my D2S bulbs from them No issues, quick warm up and amazing light output
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
04G35NYC
Winter Setups
34
Jun 2, 2016 09:12 AM
ENTRAPM3NT
Sep 16, 2015 01:21 AM
