Road to 300HP NA
Old Jun 5, 2017 | 03:59 PM
  #106
G35freaks's Avatar
....75-100 shot kit and call it a day. Only a few hundred bucks at the right shop. GL with anything otherwise.
....and is that your name on your tires????
Old Jun 16, 2017 | 03:40 PM
  #107
06G35Coupe94's Avatar
I actually have a 100shot zex kit sitting in my trunk lol. And yes its my instagram name
Old Jun 16, 2017 | 03:45 PM
  #108
UPDATE
So I installed the new oem plenum gasket, blox 5/8 spacer, and oem plenum (that I painted). Car ran amazing, so happy to get some logs to get her re tuned. Unfortunately today while driving, SES light popped on, and its the same P2A00 code. The same code I was dealing with with my kinetix plenum and the reason why I replaced it. Starting to think its just the sensor, what are your thoughts on this? Waiting for my engine to cool down and re torque all the bolts and check everything again
Old Jul 24, 2017 | 01:02 PM
  #109
DYNO ON FRIDAY
Finally hitting the dyno. Have the car running great. However there is a catch. The tune on the car right now was for my old V+ plenum. I now have an OEM plenum with 5/8 spacer. I sent new logs off to get retuned but if I dont get them back in time, ill be on the dyno with the old tune. Not sure how much itll help or hurt but at least ill see where my car is right now.
Old Jul 27, 2017 | 09:54 AM
  #110
Fastmodz's Avatar
Originally Posted by 06G35Coupe94
Just documenting my goal to 300HP on my 06 Nonrev Coupe. I have a playlist on YouTube already with videos so if you're interested check it out!
Mods as of now:
Stillen ZTube/Air Box
NWP 75mm TB
Kinetix V+ Plenum
ART Pipes
XYZ Pipe & Resonator
Nismo Rep Exhaust
1 Piece Aluminum Driveshaft
https://www.youtube.com/playlist?lis...luqHTIDIqwrnzL
Thank you for this list and the videos. I can not wait to read more and see the progress of this build. If your looking into parts, come check us out!
Old Jul 28, 2017 | 01:49 PM
  #111
Thanks! I will check you guys out
Old Jul 28, 2017 | 01:51 PM
  #112
So as I suspected. I guess not having an updated tune and 83% humidity does mess with dyno numbers.
Old Jul 28, 2017 | 05:40 PM
  #113
G2B35AGN's Avatar
An updated tune isn't going to change those numbers upward 48 horsepower, more like 4-8 HP. And humidity is good; water in the air adds more boom to the combustion. It's why NASCAR and Indy car qualifiers love to go right before it rains.
Old Jul 28, 2017 | 05:49 PM
  #114
lol I know that. I was only expecting up to 265. Thats comparing to other guys ive seen with similar mods as I have. So thats why I said not getting it retuned for the new plenum really messed it up more than I thought. I still have a lot to do before coming near or anywhere near the 300 mark. My goal is to get as close to it as possible
Old Jul 28, 2017 | 06:08 PM
  #115
yosip1115's Avatar
lol I know that. I was only expecting up to 265. Thats comparing to other guys ive seen with similar mods as I have. I still have a lot to do before coming near or anywhere near the 300 mark. My goal is to get as close to it as possible
What are you planning for mods to get there?
Old Jul 28, 2017 | 06:13 PM
  #116
I have RPM longtubes on the way, have been shipping them out so should get mine soon, ported upper/lower plenum, ported intake runner, then cams. After that ill literally have every bolt on lol so if I dont get near 300 after the cams then its whatever. Ill throw on the ZEX nitrous kit I have sitting in my trunk lol
Old Jul 28, 2017 | 07:03 PM
  #117
yosip1115's Avatar
You could do direct port nos when you have the machining done... Then you'll definitely hit 300. Probably would want to keep it to a 50 shot or something. You should get a dyno tune after the cams and all of that, then street tune after if needed. The nos is a different story. You'll want someone who has done that before I would think
Old Jul 28, 2017 | 08:19 PM
  #118
Definitely I was looking more into the direct port and think I wanna go that route. Yeah Ive been doing street tuning through Pat at LMT. Recording logs, sending them off and receiving the tune.
Old Jul 28, 2017 | 08:23 PM
  #119
UPDATE
So after speaking to Pat over at LMT (guy who makes the intakes and tunes my car), he actually informed me that he tuned my car back from the last set of logs I sent him because the knock sensor detected some knock and wanted to see what was causing it and not let my **** blow up lol. So with the new set of logs I sent and the new tune waiting to be received, I should 100% be seeing numbers in the 260s
Old Jul 28, 2017 | 11:52 PM
  #120
ScraggleRock's Avatar
Lol.almost there, bud.
