03-04 vs 05-06 interiors
Old May 21, 2008 | 08:51 AM
  #31
lexusk8's Avatar
Originally Posted by Lucky-G
What about switching out an 03-04 shifter for an 05-06 style?
It has been successfully done by another member on the forum (see the DIY link below).
https://g35driver.com/forums/g35-sedan-v35-2003-06/188322-2003-sedan-center-console-upgrade-fx-shift-panel-shift-knob-titanium-paint.html
Old May 21, 2008 | 01:13 PM
  #32
Wannabe6MT's Avatar
-MN G Crew-
^thats an FX shifter. Not an 05-06 G shifter.
I dont think an 05-06 G shifter would fit. Its more narrow and theres a big piece.
Old May 21, 2008 | 03:07 PM
  #33
psedog's Avatar
Back in SD**
No, the shifter is an 05-06 shifter. The panel is from an fx.
Now I attempted to install the new 05-06 shift ****. I thought this was a direct swap with the new shift adaptor. Wrong. The two groves on the sides of the metal pole where the spring clip secures the shift **** onto the pole are about 1/4 inch below where the groves are on the shift **** are. I attempted to cut new groves in the white plastic on the sides of the shift **** 1/4 inch lower (so I could still use the spring clip to secure the shift ****). This initially worked, but then I couldn't get the top of the "leather" boot on the FX shift panel to snap onto the bottom of the shift **** because the spring clip was now in the way. After about an hour of trying to cut parts of the top of the shift boot, I finally realized to use a small screw to secure the shift **** onto the pole by screwing it into one hole on the back of the pole. This worked, but again the shift boot wouldn't snap onto the shift **** because of the new obstruction. After more cursing and cutting away of things in the shift boot clip, it finally snapped together.
Old May 21, 2008 | 03:11 PM
  #34
psedog's Avatar
Back in SD**
Wait here is a better quote. His parts list...
Originally Posted by GixxerSteve
The parts you need for this conversion are listed in my original post up top:
(1) 06+ FX shift panel http://www.trademotion.com/partlocat...catalogid=3323
(1) 2005-2006 G35 AT shift ****
(1) Shifter adaptor for the 05-06 ****
(3) sheetmetal screws 4X - 5/8"
(2) sheetmetal screws 6X - 3/8"
(1) wood screw 6X - 5/16"
I got the shift panel, shift **** and shift adaptor from Infiniti. The screws I got from Ace. Total cost for the parts was about $200.
Picture Share
Feb 4, 2018 12:41 PM
nissandrifter32
Dec 22, 2015 04:28 PM
prinny
Nov 22, 2015 11:07 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
