OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Oct 13, 2010 | 10:10 PM
  #2161
G35Papa's Avatar
Start with some sway bars Chris when you get the funds. Sounds like Fabrikator has a nice fix too
Old Oct 13, 2010 | 10:11 PM
  #2162
forweareLegion's Avatar
In fact, I am. Probably not AS low (as I deem my car needs to function), but certainly as far as stance goes, aggressive.
19x10 +20, 245/35.
When my trunk isnt full of my work **** and is on level ground, the front tire sits just inside the front wheel well, as does the rear.
I believe its a combination of the suspension setup, how I pulled the front fenders, the fact I moved the corner light out (with said fender pulling) and mainly, sheer luck.
Old Oct 13, 2010 | 10:15 PM
  #2163
Johnnyone's Avatar
sway bars was prob my favorite mod.
Originally Posted by forweareLegion
I have not once popped a side marker, and my car is probably driven harder than the majority of yours combined. Did the math.
Lol at your comment.
Being that you drive your car so hard you prob arent slammed with aggressive fitment. Pics of your car and your wheel specs?
edit: seeing your pics and specs now. guess u are lucky. I pulled my front and and was at +9 on 9" on 225's and my lights popped out. guess i should have did the bracket mod.
Old Oct 13, 2010 | 10:23 PM
  #2164
CandlestickPark's Avatar
ill Sedan
forweareLegion you are just about as aggressive as me up front (1mm less) but you aren't as low. That and the reasons you stated in your post are probably why you haven't popped a side marker. Your setup looks good I would bring the front down a bit (but then it wouldn't be as functional, which is what you are looking for since you drive your car hard).
Old Oct 13, 2010 | 10:40 PM
  #2165
Yes probably why. I agree, I'd like to get the front down a bit, even the rear. But this is what suits how I drive, and the streets the car is driven on. It works I suppose. Honestly, given what the car was through over the summer its suprizing a fender liner/lights/everything around the wheels didnt grenade. Mountain roads will be the death of it sooner or later.
Old Oct 13, 2010 | 10:56 PM
  #2166
Heist.'s Avatar
forweareLegion yeah your not low enough to really have the problem. Like your setup though.
my brackets are so bent haha. Far from functional
Old Oct 13, 2010 | 10:57 PM
  #2167
Matzo Ball's Avatar
how hard would it be to fit a 19x9.5/19x10.5 +25 all around? Would run 225/40 and 255/35 respectively.
Old Oct 13, 2010 | 11:29 PM
  #2168
NAT@FFTec's Avatar
ah the good ol' side marker popping out....LOL i gotta pop my driver side marker back in every time i go for a drive
Old Oct 14, 2010 | 01:37 PM
  #2169
ill Sedan
Those will fit, fronts will need a spacer. With a 255/35 and ~-3 degrees of camber out back you'll need about an 8mm fender pull.
Old Oct 14, 2010 | 01:56 PM
  #2170
Matzo Ball's Avatar
just wondering....Thanks Marcus
Old Oct 14, 2010 | 02:02 PM
  #2171
4DGS's Avatar
^ or stretch a little more, roll flat and you'll be fine as well.
(say 245/35)
Old Oct 14, 2010 | 02:06 PM
  #2172
Matzo Ball's Avatar
(say 245/35)
Rolled flat now. 225/40 and 255/35 have same OD (damn the X )
Old Oct 14, 2010 | 08:48 PM
  #2173
JDM_Cain's Avatar
I have stillen front and rear sway bars...ill try Fabrikators idea this weekend..
Old Oct 15, 2010 | 12:23 PM
  #2174
geesteezd's Avatar
What tire size would be suitable to fit 19x9.5 +22 all around? Thanks in advance!
Old Oct 15, 2010 | 12:31 PM
  #2175
ill Sedan
How low are you? A 225 or 235 is a nice stretch on a 9.5. With those tires sizes you'll need spacers front and rear. Would need to be tucking tire to run those tire sizes.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
