OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Nov 14, 2010 | 08:59 PM
  #2386
CG4DR's Avatar
how much camber would i need to pull off a 19x9.5 et20 or 40 in the rear?
Old Nov 14, 2010 | 09:07 PM
  #2387
CandlestickPark's Avatar
ill Sedan
What tire size? I had -2.75 camber when I was running 9.5 +20 with a 255/35. With a 245/35 it would be around -1.75 to -2.0. With a 235/35 you'd be back within OEM spec for camber. This assumes your fenders are rolled very flat.
Old Nov 14, 2010 | 09:12 PM
  #2388
CG4DR's Avatar
i was thinking a 245.. i want to stay around -2.0 to -2.5 bc thats where i am at now and have no excessive tire wear
Old Nov 14, 2010 | 09:14 PM
  #2389
ill Sedan
You are pretty low, I forgot, so it will be a bit more camber than I noted. I was only lowered 2.5" back then. You'll be able to be within that range though with a 245 (one that runs small or true). You just gotta make sure you fenders are rolled really flat.
Old Nov 14, 2010 | 09:25 PM
  #2390
CG4DR's Avatar
about -3.0?
Old Nov 14, 2010 | 09:28 PM
  #2391
ill Sedan
Yeah no more than -3. TycoRC is running the same tire sizes and specs (and he's lowered 3" or so) I think he's at -3 camber. I think with a super flat roll though you'll be in the mid -2s. You could just go with a 235 to give you more clearnace, its hardly any stretch, same stretch as what I'm running.
Old Nov 14, 2010 | 10:24 PM
  #2392
dz n.u.t.z.'s Avatar
Got New wheels . Pics soon. Back is nice and tight. Still working on the front. Can't turn with my spacers on, and I'm NOT raising it up!!!! **** that.
Old Nov 14, 2010 | 10:26 PM
  #2393
O specs are 20x9.5 et 23 but once my spacers are back on it will be et.8.
Back is 20x10.5 et 24
Old Nov 14, 2010 | 10:29 PM
  #2394
Matzo Ball's Avatar
I am on springs so I have more compression than you probably and I am running 19.9.5 +30 rear at -2.5* camber. i still have about 4mm clearance and running a 255/35. I will be going 9.5 +25 and -2.75* camber. If you have your coils set to a stiffer setting you could easily do 9.5 +20 with a flat roll on 245s easily!
Old Nov 14, 2010 | 10:31 PM
  #2395
Matzo Ball's Avatar
dznutz, what wheels did you get? Over/under is that you keep them for 3 months then switch up again.
Old Nov 15, 2010 | 12:17 AM
  #2396
only one for now.
Old Nov 15, 2010 | 12:34 AM
  #2397
FlyingLumpia's Avatar
Volks?
Old Nov 15, 2010 | 01:46 AM
  #2398
ill Sedan
Cliff I didn't think you'd be able to run 20s at your ride height. You are definitely tucking rim in the rear...haha. Can't wait to see better pics.
Old Nov 15, 2010 | 07:26 AM
  #2399
Yea gt30's
Old Nov 15, 2010 | 10:00 AM
  #2400
simin510's Avatar
You have good choice
Everything you do to your car looks sick !!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
