OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Aug 6, 2009 | 01:14 AM
gtrefever's Avatar
HAHA YEAH well mine is 10+24 and had more room with a 235/35. Grant pm ima have my fronts soon and ill probably get tires in another 2 weeks. gotta get this set before the big sedan meet. but im sad that i didnt find any spacers for cheap so can you take away some camber that i have now to have it super flush
Old Aug 6, 2009 | 01:33 AM
NAT@FFTec's Avatar
man...looks like ill be keeping the volks for a while...seems like its not the right timing for me to switch wheels and what not especially when im preparing to move down to socal . well hopefully ill find something i like once i move down
Old Aug 6, 2009 | 01:42 AM
gtrefever's Avatar
all good nat. your set up now is still money, are you going to go to the big sedan meet?
Old Aug 6, 2009 | 01:43 AM
ShanesG's Avatar
Noice!
Old Aug 6, 2009 | 03:24 AM
NAT@FFTec's Avatar
oh fsho
Old Aug 8, 2009 | 10:47 AM
FlyingLumpia's Avatar
Do you guys think it will look stupid if I went 245/35/19 on a 9 front and then stretch a 245/35/19 on a 10 rear.
Old Aug 8, 2009 | 12:42 PM
CandlestickPark's Avatar
ill Sedan
^IMO it would look better if you run about the same amount of stretch on each tire.
Also the fitment should be about the same too. In my setup I had a 5mm spacer up front and a 10m out back at first, but then the front looked way too tucked compared to the rear being beyond flush. I went with a 10mm up front and that evened it out.. Could probably go with a 15mm up front to match the fitment in the rear even more but I'd have to run a slightly smaller tire size.
Old Aug 8, 2009 | 01:10 PM
humm so either go with a 245/255 set up or 225/255 set up. The only problem with the 225/255 that tire selections is limited. Well they have hanooks and I heard they stretch pretty good.
Old Aug 8, 2009 | 01:33 PM
apintojr's Avatar
i use to run Hankook Ventus. they are noisy. after about 1 year with them i couldnt take the tire noise.
Old Aug 8, 2009 | 01:57 PM
gtrefever's Avatar
honestly there wouldnt be a stretch with a 245/35 on a 9 but a 245/35 on a 10 theres a slight stretch. depending on the offsets but id runa 225/35f 245/35 rear
Old Aug 8, 2009 | 02:11 PM
Remember I have an X so the diameter got to be close as possible also I want to make sure my speedo is not that off. Also I remember Grant saying that a 255 will be a slight stretch.
Old Aug 8, 2009 | 02:16 PM
gtrefever's Avatar
i can take a pic of a 245/35 on a 10 right now its a slight stretch.
Old Aug 8, 2009 | 02:39 PM
I know its a slight stretch. But so is a 255 on a 10. Again, it might mess up the awd if I ran a 225/245.
Old Aug 8, 2009 | 02:55 PM
gtrefever's Avatar
255= 10 inchs.
why not run 235/40s all around
Old Aug 8, 2009 | 03:18 PM
  #30
I think I will just run 245/255 and see how that goes.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
