OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Apr 4, 2011 | 06:35 PM
  #3316
CandlestickPark's Avatar
ill Sedan
Your 245s on a 9.5 might run small. Tire sizing is not consistent between brands. When you choose a tire you should consider whether it runs small, true or large.
Old Apr 4, 2011 | 06:44 PM
  #3317
CG4DR's Avatar
true, they are fk452s which i think run skinnier
Old Apr 4, 2011 | 08:00 PM
  #3318
SN00P's Avatar
CLUB MODERATOR
post pictures !!!! ^^^ lets see your stance !
Old Apr 4, 2011 | 08:06 PM
  #3319
ill Sedan
Started daily driving again after Wekfest (Feb). Boy did I miss driving my car everyday.
Old Apr 4, 2011 | 10:54 PM
  #3320
Gdup35sedan's Avatar
ENVautoDetailing.com
Gas for the truck getting too expensive?!
Old Apr 4, 2011 | 11:10 PM
  #3321
ill Sedan
^LOL, nah I just got tired of letting my car sit 5 or 6 days a week. My oldest son really enjoys riding in the car, so that was another motivation.
Truck doesn't take premium but eats a lot of gas. Probably am saving some money by driving the G.
Old Apr 4, 2011 | 11:12 PM
  #3322
D.Reaper's Avatar
do i qualify now? and if i do, it was not intentional...i was going for a flush look, but i overshot it with the spacer
and front, how it was supposed to come out
Old Apr 4, 2011 | 11:13 PM
  #3323
I'm just glad you're rolling hard again like most of us!
Old Apr 4, 2011 | 11:15 PM
  #3324
Needs more low in the rear and some stretched tires to clear the front from pulling the fender.
What size spacers did you end up going with?
EDIT: Did a little searching and found that you went with 25mm spacers all around...
I was the first one to reply when you asked and told you to go with 20mm spacers all around. This is why I get multiple PM's a day about wheel fitment, LOL!!!
Old Apr 4, 2011 | 11:19 PM
  #3325
ill Sedan
Haha, jeah buddy. Rollin' dumpt daily
Old Apr 4, 2011 | 11:23 PM
  #3326
D.Reaper's Avatar
i'm good with how the front sits, i shoulda listened about the rear...i measured the rear and it seemed to have about 1" clearance, so i thought i could push it...i bought the eastwood fender finisher and pinched all 4 corners...gonna go down to a smaller spacer, what size now looking at how it ended up? 20mm finally?
Old Apr 4, 2011 | 11:26 PM
  #3327
My rule of thumb, whatever you end up measuring, take off 5mm and go with that. It hasn't failed me yet (knocks on wood) If the front doesn't rub right now then i'd stick with that and drop down to a 20mm in the rear.
Old Apr 4, 2011 | 11:34 PM
  #3328
D.Reaper's Avatar
sounds good man, i appreciate the help
Old Apr 5, 2011 | 12:54 PM
  #3329
Matzo Ball's Avatar
Reaper, looks good. You can dial in a touch of neg camber in the rear if you want. Much better though.
Old Apr 5, 2011 | 01:13 PM
  #3330
The Stimulation's Avatar
Posted this in the aggressive thread, will post here for the other sedan guys to see...
Ummm, yeah. Sh*t ain't happening. If I can't get into my driveway, I definitely can't get anywhere in LA. It's not that steep. Rear is raised 2" from maxed out position. Fronts are close to maxed out so I have a raked stanced. Only doing that since one side of my rear fenders is cut, the other needs cutting, and I need to hammer the rears out more. Don't want any metal to dig into the tires or and tire rubbing (or scraping the freshly powdercoated wheels on the inner fenders).
Rocking no front bumper right now, might throw on the kenstyle back on after everything is adjusted or find an oem, i'll see what's up.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
