OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Jul 10, 2011 | 11:16 PM
  #4141
hey Marcus, 19x8.5 +30 front 19x10+ 38 rear on 235/35 and 265/30. Wat size spacers should I do f and r? not much camber, pretty even right now? Lowered on bc's.
Reply 0
Jul 10, 2011 | 11:26 PM
  #4142
^So is your camber within spec (-1.X)? How much camber would you like to run? How low are you? Pic of your car at current ride height?
Reply 0
Jul 11, 2011 | 12:08 AM
  #4143
Our list hasn't been updated for a long while. For the guys with agressive stretched setups, please update. This has been useful to many here.
Donpisto
Wheel spec
20x9.5 -12
20.10.5 +0
Tires225/35
Camber: Front camber is -4.7 and rear camber is -7.5
Fender Work:rear were rolled flat, pulled and flared upward (upward flare not needed/not beneficial).
Gtfever:
Wheel Specs:
19x9+4
19x10-1
Tires:
215/35
225/35
Camber: -3 camber upfront and -4 out back
Fender work: Pulled
4drmadness
Wheel Specs:
Volk Winnings
19x9.5 +17
19x10.5 +19
Tires:
225/35/19
235/35/19
Camber: -3.8 back and -2.4 front
Fender work rolled flat
STCLAIRWEST
Wheel Spec:
19x9.5 +17
19x10.5 +9
Tires:
225/35/19
245/40/19
Camber: -2.5(fr) -2(r)
Fender Work: Pulled
dz n.u.t.z
Wheels Spec:
TE Rep
19x9.5 + 7
19x10.5 +22
Tires:
235/35/19
265/30/19
Wheel Spec:
Challenges
19x9.5 + 16
19x10.5 +23
Tires:
Nexens 245/35/19
Dunlop 275/30/19
Camber: -3.3
Fender work: Pulled
4DGS
Wheel Specs:
19x9 +10
19x10 +17
Tires:
Falken Fk452 215/35/19
Falken FK452 225/35/19
Camber: 2.3 all around
Fender Work: Mild roll
sag35777
Wheel Specs
19 x 9 +15
19 x 10 +15
Tires:
nexen 3000 235/35
nexen 3000 245/35
Camber: ???
Fender work:???
Johnnyone
Wheel Specs:
19x9 +9
19x10 +20
Tires:
Toyo Proxes T1R 225/35/19
Toyo Proxes T1R 245/35/19
Camber: -3.5 all around
Fender Work: Pulled
FlyingLumpia
Wheel Specs:
19x9 +32 with a 15mm spacer
19x10 +32 with a 10mm spacer
Tires:
225/40
255/35
Camber:???
CandlestickPark
Wheel Specs:
19 x 8.5 +0 (25mm spacer)
19 x 9.5 +10 (20mm spacer)
Tires:
Yokohama S-drive 225/35/19
Yokohama S-drive 235/35/19
Camber: -3 F, -4R
Fender Work: Rears pulled 5mm, fronts pinched flat and flared
NAT&FFec
Wheel Specs
19x8.5+22
19x9.5+22
Tires:
255/35/19
255/35/19
Camber:-2F/-3R
Fender work: Rears rolled flat fronts pulled
TycoRC
Wheel Spec:
19x8.5 +20 JLBMotorsport Apollo's
19x9.5 +20
Tires:
Nexen N3000235/35/19
Nexen N3000245/35/19
Camber: -3.3 Front -3.75 Rear
Fender Work: Rolled very flat
Fabrikator
Wheel Spec:
20x9.5 +14 (R-disk) Work Gnosis GS-3
20x10.5 +20 (O-disk)
Tires:
Falken FK452 - 235/30/20
Falken FK452 - 255/30/20
Camber -3.3 Front, -6.0 Rear
Fender Work: Front - Rolled very flat and slight pull, Rear - Pulled
Reply 0
Jul 11, 2011 | 12:09 AM
  #4144
Quote: ^So is your camber within spec (-1.X)? How much camber would you like to run? How low are you? Pic of your car at current ride height?
o sorry, forgot to mention. camber is within spec, tires sit pretty square. dont have pictures of the new wheels on the car, but here is a old photo to go by. im gonna drop the car half inch to inch from this photo. hope that helps. figured ill being poking, trying not to run much negative camber, but dont mind running camber to pull off the look with 265/30 rear.
OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan-jeff-1032.jpg   OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan-jeff-1034.jpg
Reply 0
Jul 11, 2011 | 12:18 AM
  #4145
Quote: hey Marcus, 19x8.5 +30 front 19x10+ 38 rear on 235/35 and 265/30. Wat size spacers should I do f and r? not much camber, pretty even right now? Lowered on bc's.
Quote: o sorry, forgot to mention. camber is within spec, tires sit pretty square. dont have pictures of the new wheels on the car, but here is a old photo to go by. im gonna drop the car half inch to inch from this photo. hope that helps. figured ill being poking, trying not to run much negative camber, but dont mind running camber to pull off the look with 265/30 rear.
I would aim to be at:
8.5 +15 (+30 w 15mm spacer)
10 +28 (+38 w 10mm spacer)
Fronts will need to be pinched flat with a fender finished. Rears will need to be rolled flat.
If the wheels are already on the car you can measure to see if what I've recommended comes close to how you want to run them. If a local friend has spacers you can try different sizes to see how flush you wanna be.
Reply 0
Jul 11, 2011 | 12:59 AM
  #4146
Quote: Our list hasn't been updated for a long while. For the guys with agressive stretched setups, please update. This has been useful to many here.
Donpisto
Wheel spec
20x9.5 -12
20.10.5 +0
Tires225/35
Gtfever:
Wheel Specs:
19x9+4
19x10-1
Tires:
215/35
225/35
Fender work: Pulled
4drmadness
Wheel Specs:
Volk Winnings
19x9.5 +17
19x10.5 +19
Tires:
225/35/19
235/35/19
STCLAIRWEST
Wheel Spec:
19x9.5 +17
19x10.5 +9
Tires:
225/35/19
245/40/19
Fender Work: Pulled
dz n.u.t.z
Wheels Spec:
TE Rep
19x9.5 + 7
19x10.5 +22
Tires:
235/35/19
265/30/19
Wheel Spec:
Challenges
19x9.5 + 16
19x10.5 +23
Tires:
Nexens 245/35/19
Dunlop 275/30/19
Camber: -3.3
Fender work: Pulled
4DGS
Wheel Specs:
19x9 +10
19x10 +17
Tires:
sag35777
Wheel Specs
19 x 9 +15
19 x 10 +15
Tires:
nexen 3000 235/35
nexen 3000 245/35
Camber: ???
Fender work:???
Johnnyone
Wheel Specs:
19x9 +9
19x10 +20
Tires:
Fender Work: Pulled
FlyingLumpia
Wheel Specs:
Tires:
225/40
255/35
Camber:???
CandlestickPark
Wheel Specs:
Tires:
Camber: -3 F, -4R
NAT&FFec
Wheel Specs
19x8.5+22
19x9.5+22
Tires:
255/35/19
255/35/19
Camber:-2F/-3R
TycoRC
Wheel Spec:
19x9.5 +20
Tires:
Fabrikator
Wheel Spec:
Tires:
Speeddream
Front: 18X9+2 with a 20mm spacer
Rear: 18x10+9 with a 15mm spacer
Tires:
215-40-18
245-40-18
Camber: N/A yet
Fender: front rolled flat and pulled about 3mm, rear rolled real flat pulled about 3mm
Reply 0
Jul 11, 2011 | 01:17 AM
  #4147
JDM_Cain
Front: 19x9.5+2 with 20mm spacers
Rear: 19x11+24 with 5mm spacers
Tires:
Falken fk452
235/35f
255/35r
Camber: aprox -2.5
Fender: Front rolled flat (side marker bracket modified), rear rolled flat and pulled 5mm
Reply 0
Jul 11, 2011 | 01:18 AM
  #4148
Donpisto
Wheel spec
20x9.5 -12
20.10.5 +0
Tires225/35
Gtfever:
Wheel Specs:
19x9+4
19x10-1
Tires:
215/35
225/35
Fender work: Pulled
4drmadness
Wheel Specs:
Volk Winnings
19x9.5 +17
19x10.5 +19
Tires:
225/35/19
235/35/19
STCLAIRWEST
Wheel Spec:
19x9.5 +17
19x10.5 +9
Tires:
225/35/19
245/40/19
Fender Work: Pulled
dz n.u.t.z
Wheels Spec:
TE Rep
19x9.5 + 7
19x10.5 +22
Tires:
235/35/19
265/30/19
Wheel Spec:
Challenges
19x9.5 + 16
19x10.5 +23
Tires:
Nexens 245/35/19
Dunlop 275/30/19
Camber: -3.3
Fender work: Pulled
4DGS
Wheel Specs:
19x9 +10
19x10 +17
Tires:
sag35777
Wheel Specs
19 x 9 +15
19 x 10 +15
Tires:
nexen 3000 235/35
nexen 3000 245/35
Camber: ???
Fender work:???
Johnnyone
Wheel Specs:
19x9 +9
19x10 +20
Tires:
Fender Work: Pulled
FlyingLumpia
Wheel Specs:
Tires:
225/40
255/35
Camber:???
CandlestickPark
Wheel Specs:
Tires:
Camber: -3 F, -4R
NAT&FFec
Wheel Specs
19x8.5+22
19x9.5+22
Tires:
255/35/19
255/35/19
Camber:-2F/-3R
TycoRC
Wheel Spec:
19x9.5 +20
Tires:
Fabrikator
Wheel Spec:
Tires:
Speeddream
Tires:
215-40-18
245-40-18
Camber: N/A yet
JDM_Cain
Tires:
Falken fk452
235/35f
255/35r
Camber: aprox -2.5
Reply 0
Jul 11, 2011 | 07:22 AM
  #4149
Update for mine 19x10.5 et.12 235/35 front 19x10.5 et.22 255/35 rear. Camber -3.4 all around.
Reply 0
Jul 11, 2011 | 10:04 AM
  #4150
Can update mine as well....
20x10.5 +0
20x11 -12
Tires235/30 (front) and 235/35 rear
Camber: Front camber is -5.5 and rear camber is -8
Fender Work:rear were rolled flat, pulled, hammered and flared upward. front was pinched with fender finisher.
Other: This setup requires modified front upper A arms, and modified rear camber and toe arms.
Reply 0
Jul 11, 2011 | 10:18 AM
  #4151
CORNELL
19x10 +10(20mm spacer) VOLK RE30
19X11 +25
235/35 Achilles atr
245/35 Achilles atr
camber: -3 front, -4 rear
fenders rolled flat slight pull
Reply 0
Jul 11, 2011 | 10:51 AM
  #4152
The Stimulation/Donpisto
Wheel spec
20x9.5 -12
20.10.5 +0
Tires225/35
20x10.5 +0
20x11 -12
Gtfever:
Wheel Specs:
19x9+4
19x10-1
Tires:
215/35
225/35
Fender work: Pulled
4drmadness
Wheel Specs:
Volk Winnings
19x9.5 +17
19x10.5 +19
Tires:
225/35/19
235/35/19
STCLAIRWEST
Wheel Spec:
19x9.5 +17
19x10.5 +9
Tires:
225/35/19
245/40/19
Fender Work: Pulled
dz n.u.t.z
Wheels Spec:
TE Rep
19x9.5 + 7
19x10.5 +22
Tires:
235/35/19
265/30/19
LM reps
19x10.5 +12
19x10.5 +22
Tires
235/35
255/35
Wheel Spec:
Challenges
19x9.5 + 16
19x10.5 +23
Tires:
Nexens 245/35/19
Dunlop 275/30/19
Camber: -3.3
Fender work: Pulled
4DGS
Wheel Specs: WEDS
19x9 +10
19x10 +17
Tires:
Wheel specs: CCWs
18x10 +12
18x11 +20
Tires:
225/40
255/35
Camber: Rear -4.7 Front -3.7
Fenders:
rear pulled to fit
Fronts untouched.
sag35777
Wheel Specs
19 x 9 +15
19 x 10 +15
Tires:
nexen 3000 235/35
nexen 3000 245/35
Camber: ???
Fender work:???
Johnnyone
Wheel Specs:
19x9 +9
19x10 +20
Tires:
Fender Work: Pulled
FlyingLumpia
Wheel Specs:
Tires:
225/40
255/35
Camber:???
CandlestickPark
Wheel Specs:
Tires:
Camber: -3 F, -4R
NAT&FFec
Wheel Specs
19x8.5+22
19x9.5+22
Tires:
255/35/19
255/35/19
Camber:-2F/-3R
TycoRC
Wheel Spec:
19x9.5 +20
Tires:
Fabrikator
Wheel Spec:
Tires:
Speeddream
Tires:
215-40-18
245-40-18
Camber: N/A yet
JDM_Cain
Tires:
Falken fk452
235/35f
255/35r
Camber: aprox -2.5
CORNELL
19X11 +25
235/35 Achilles atr
245/35 Achilles atr
Updated
Chris, is that 19x11 +24 + 5mm spacer or effective +24 WITH 5mm spacer?
Reply 0
Jul 11, 2011 | 12:00 PM
  #4153
19x9 +5
19x10 +10
Tires: 225/35 235/35
Camber: -3.5/-4.0
Fenders: rolled and pulled 5mm F&R
Reply 0
Jul 11, 2011 | 12:52 PM
  #4154
Dammit Grant lol
Wheel spec
20x9.5 -12
20.10.5 +0
Tires225/35
20x10.5 +0
20x11 -12
Gtfever:
Wheel Specs:
19x9+4
19x10-1
Tires:
215/35
225/35
Fender work: Pulled
4drmadness
Wheel Specs:
Volk Winnings
19x9.5 +17
19x10.5 +19
Tires:
225/35/19
235/35/19
STCLAIRWEST
Wheel Spec:
19x9.5 +17
19x10.5 +9
Tires:
225/35/19
245/40/19
Fender Work: Pulled
dz n.u.t.z
Wheels Spec:
TE Rep
19x9.5 + 7
19x10.5 +22
Tires:
235/35/19
265/30/19
LM reps
19x10.5 +12
19x10.5 +22
Tires
235/35
255/35
Wheel Spec:
Challenges
19x9.5 + 16
19x10.5 +23
Tires:
Nexens 245/35/19
Dunlop 275/30/19
Camber: -3.3
Fender work: Pulled
4DGS
Wheel Specs: WEDS
19x9 +10
19x10 +17
Tires:
Wheel specs: CCWs
18x10 +12
18x11 +20
Tires:
225/40
255/35
Fenders:
rear pulled to fit
Fronts untouched.
sag35777
Wheel Specs
19 x 9 +15
19 x 10 +15
Tires:
nexen 3000 235/35
nexen 3000 245/35
Camber: ???
Fender work:???
Johnnyone
Wheel Specs:
19x9 +9
19x10 +20
Tires:
Fender Work: Pulled
FlyingLumpia
Wheel Specs:
Tires:
225/40
255/35
Camber:???
CandlestickPark
Wheel Specs:
Tires:
Camber: -3 F, -4R
NAT&FFec
Wheel Specs
19x8.5+22
19x9.5+22
Tires:
255/35/19
255/35/19
Camber:-2F/-3R
TycoRC
Wheel Spec:
19x9.5 +20
Tires:
Fabrikator
Wheel Spec:
Tires:
Speeddream
Tires:
215-40-18
245-40-18
Camber: N/A yet
JDM_Cain
Tires:
Falken fk452
235/35f
255/35r
Camber: aprox -2.5
CORNELL
19X11 +25
235/35 Achilles atr
245/35 Achilles atr
Gdup35sedan
PIAA Supper rozzas
19x9 +5
19x10 +10
Camber: -3.5/-4.0
XXR 521
18x10 +15 front and back
225/40
225/45
-3 degrees of camber.
Correct me if I'm wrong on you XXRs, that's what I remember off the top of my head!
Reply 0
Jul 12, 2011 | 11:33 AM
  #4155
Hey guys im looking for some insight my 05 Sedan it is lowered on Tein S techs
and the wheels im looking at are 20x8.5/10 +20/+43
I have all stock control arms i have approx 2-3* of camber upfront and 4* in the rear
the tires i want to run will be 225/30 255/30
I just want to be KindaFlush, this is my DD and dont want anything too crazy, just a clean look
someone side swiped me on the fwy so shes in the body shop and im getting a new set of wheels while shes in. im pretty sure ill have to roll the rear fender, but i dont think i will have to do anything up front.
Thanks for the help, i love this thread your guys cars are sick!
Reply 0
