OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jul 12, 2011 | 11:38 AM
  #4156
Gdup35sedan's Avatar
ENVautoDetailing.com
Unless you plan in going with coilovers soon, I would go with a 225/35 up front. Your car isn't low enough for a 225/30.
You'll need 15-20mm spacers in the rear depending on how aggressive you want to be. At the very least a 10mm to make you look "sortaflush"
Old Jul 12, 2011 | 12:19 PM
  #4157
4DGS's Avatar
you have -4 degrees of camber dropped on S techs?
Something is wrong....
Old Jul 12, 2011 | 12:23 PM
  #4158
The Stimulation's Avatar
Even 2-3 degrees up front is wrong with springs. On Tein Basics I was at -2.2 or -2.4.
Old Jul 12, 2011 | 12:28 PM
  #4159
black_gst's Avatar
wouldent that make the tire look kind tall in the front? I have 225/30/20 in the front right now on an 8.5 wide wheel
it might be closer to -3* I cant remember what it was at when I had it aligned.
i can get my hands on a set of Tanabe springs for cheap and i think they drop the front another .3" and have stiffer spring rates in the rear, i dont care too much for the S tech they were on the car when i bought it
im just going for a Flush look not so much the stretch and poke
Thanks for the help
Old Jul 12, 2011 | 12:29 PM
  #4160
black_gst's Avatar
im sure im just mistaken then my fault.
Old Jul 12, 2011 | 03:03 PM
  #4161
No it would not. The sidewall on a 225/35/20 and a 255/30/20 are almost identical.
Old Jul 12, 2011 | 03:55 PM
  #4162
SN00P's Avatar
CLUB MODERATOR
SN00P
Wheel Specs: concept one rs-8
19x9.5+17
19x10.5+30
Tires:
General utp 225/35
General utp 245/35
Camber: front: -3º rear: - -5.5º
Fender Work: front: all tabs removed and pinched flat and pulled 3mm rear: cut to the max.
---> working on pulling the rears soon with the great green goblin aka Danny then im looking at 10.5+15 or around there maybe a lot more aggressive
Old Jul 12, 2011 | 03:58 PM
  #4163
SN00P's Avatar
CLUB MODERATOR
Thanks for the help
then your in the wrong thread :-) there is a sorta flush thread in our section if you didnt know
this thread is for people who are stretch.poke.cambered
Old Jul 12, 2011 | 07:56 PM
  #4164
Wilg35j's Avatar
Hey guys i got a question, i got a friend that just bought xxr 527's 18 8.75 + 20 and he wants a mild strech on the tires any recommendations what size tire he should run... Thanks
Old Jul 12, 2011 | 08:25 PM
  #4165
4DGS's Avatar
^ pretty tough to stretch on that thing of a wheel. a 225/35 is very mild stretch (and a small tires)
The smallest tire he could get is probably a 215/40 and still, not that stretchy.
Old Jul 12, 2011 | 08:35 PM
  #4166
Wilg35j's Avatar
Thanks bro ill let him know...
Old Jul 12, 2011 | 08:36 PM
  #4167
4DGS's Avatar
You have to go pretty low to tuck tire on a 215/40/18
so depends on the car...
Old Jul 12, 2011 | 08:53 PM
  #4168
Wilg35j's Avatar
Yea hes pretty low is a 03 accord 4 door
Old Jul 13, 2011 | 11:45 AM
  #4169
black_gst's Avatar
I didnt know that, but I found the thread and read through it, thanks. and thanks for the help here too guys, i think i have it figured out
Old Jul 13, 2011 | 01:12 PM
  #4170
GOAT35's Avatar
Sorry im kinda off a little but I have 20s X 8.5/10 Im running 245/35/20 in the front "looks a lil high" ans 275/35/20 in the rear. I had some cheap tires at first so it fit well but now I went luxury and got continentals. However I need to find a way so that these tires wont get ate up on the insides anymore. 8 months was all I go out of the previous tires! The guy who does my alignment said i'm already maxed out...
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
