i used to drive on 2x4s to get the scissor jack to fit under.
its a pita haha but you gotta do it.
Quote:
Here is what it looks like with the boards.
Ha ha thats how i is, but with one board instead of 2 stacked.Originally Posted by Johnnyone
So if i go another half inch lower, i will not be able to use my running boards due the front bumper clearance. For the guys that are slammed, do you just use the scissor jack first then use your floor jack?Here is what it looks like with the boards.
Yea I guess I will just use one board and see if I can get the low profile Jack under it.
They wasn't joking when the said low isn't easy.
I have to drive up on a board, then Jack it up front the side, put the Jack stands in a temp spot, then Jack it up from the center Jack point, then secure the Jack stands on the sides.
I'll show you a better one later. Use 1/4 plywood, add them on top of each other in gradual steps, you'll clear just fine. Or get bags like mentioned...i'll hook you up with UAS Originally Posted by Johnnyone
^ I might have to go with uas n the future.
Is it recommended that you use the bags with the aftermarket coils or can u use stock z shocks?
try having sideskirts that sit lower than the jack point :-)Originally Posted by Johnnyone
Yea I guess I will just use one board and see if I can get the low profile Jack under it.They wasn't joking when the said low isn't easy.
Quote:
Originally Posted by STCLAIRWEST
Lmao I rather get bags with that money
Cheap Ver... made in taiwan ftl
http://www.srr.com.tw/english/e_suspension.asp
Quote:
lol that doesn't mean anything, at least you can still jack up your carOriginally Posted by gtrefever
try having jackpoints that sit lower then your sideskirts
i have to custom fab a piece of wood/metal/wuteverthefvck to put on the lifting portion of the jack to reach the jackpoint before the arm hits the sideskirt
With aftermarket coilovers you have the ability to adjust the dampening like regular coilovers. You don't need to replace the Z shocks.... lifesgood has bags and he has G shocks and it was a nice ride. Wasn't bouncy and he was riding with about a 2 finger gap. His car does feel stiff, but he has racing seats and some other stuff to stiffen the car up. I'd recommend having coilovers, but its definitely not necessary, you can always make the swap later.Originally Posted by Johnnyone
^ I might have to go with uas n the future.Is it recommended that you use the bags with the aftermarket coils or can u use stock z shocks?
I do however, recommend going with the 8 valve setup. With the 4 valve you'll have too much of a boat feeling.
I'll be going with UAS when funds permit. I'll be riding lower than what I do now and just use the bags to go up when there's a driveway. And the ability to go higher than OEM ride height is a huge plus, especially if you have an aftermarket bumper that sits lower.
Posted in the aggressive offsets thread, but figured I'd post here as well...
I might have a surprise for you fellas in a few weeks. Gonna put some spacers on in the rear...will be in double digit negatives and NOT in the teens. Just gonna try it out but I'll be dialing in some positive camber and probably adding spacers. Gonna match rear camber with the front and deal with rubbing the tire, just getting my suspension modified. For those that don't know, my rears already are a 20x10.5 +0 offset.
hey levon if you ever wanna buy my set lmk i might wanna sell them. maybe , i kinda want more aggressive t1s'
i believe the most aggressive is 9.5 -20, 10.5 -22
