OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Sep 25, 2011 | 10:43 AM
  #4561
CandlestickPark's Avatar
ill Sedan
^Thanks Chris, good seeing you yesterday.
Sittin' flush at the GTG III
Old Sep 25, 2011 | 10:50 AM
  #4562
ill Sedan
Moar
Old Sep 25, 2011 | 11:30 AM
  #4563
shawndon's Avatar
Shots look great guys. The white on white setup is . Looks like the meet was fun. Is the other white sedan rubbing at all in the front? I would like to go lower.
Old Sep 25, 2011 | 11:33 AM
  #4564
JaE35's Avatar
Moderator
G35 Sedan
fire
Old Sep 25, 2011 | 11:50 AM
  #4565
Wilg35j's Avatar
Wow ..
Old Sep 25, 2011 | 12:28 PM
  #4566
Matzo Ball's Avatar
white on white is just clean. Fits the theme well. Specs? Fender to ground measurements?
PIAAs look perfect on Grants IP.
Old Sep 25, 2011 | 01:17 PM
  #4567
JDM_Cain's Avatar
Hey guys, The specs on the wheels are 9.5 +2 (20mm spacer) 10.5 +22. Wheels are 19" CE28 JSpec edition, very rare. Fender to ground is aprox 24.5 inches. Haven't measured it in a while though....
Old Sep 25, 2011 | 01:43 PM
  #4568
jimmyboi860's Avatar
so i have an 05 g35 sedan, and i've finally decided to buy these wheels. Before i buy them though these are the specs:
Wheel Size: 20x9 (Front), 20x11 (Rear)
Bolt Pattern/Offset: 5x114.3/120 +15
(245/35/20) Front
(275/30/20) Rear
I posted in the sedan section and people are telling me these will not fit on my car with modifications. Can someone help me out by telling me what i would have to do in order to make these fit these on my sedan. thanks!
Old Sep 25, 2011 | 01:49 PM
  #4569
narrower tires? help plz
Old Sep 25, 2011 | 02:41 PM
  #4570
FlyingLumpia's Avatar
Narrow tires. Pulled fenders and good amount neg cAmber.
Old Sep 25, 2011 | 03:47 PM
  #4571
Gdup35sedan's Avatar
ENVautoDetailing.com
Youll need atleast -5 camber with 245's on the rear to fit a 20x11 +15. Plus a 5-10mm fender pull
Old Sep 25, 2011 | 03:52 PM
  #4572
shawndon's Avatar
+1. I'm running 20x10 +18 with a 255/35 in the rear. Camber is a -5 with fenders rolled flat and a 10mm or more fender pull.
Old Sep 25, 2011 | 04:04 PM
  #4573
and how about the front?
Old Sep 25, 2011 | 04:54 PM
  #4574
Run a 225 you will be fine in the front. Btw post what kind of wheels they are.
Old Sep 25, 2011 | 05:11 PM
  #4575
I decided to go with the XXR 526s.
20x9 front 20x11 rear
e7d75f20.jpg?t=1312326721
NEED ADVICE FOR FITMENT TOO!!! ;p
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
