OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jun 29, 2012 | 02:58 PM
  #5821
4drmadness's Avatar
Old Jun 29, 2012 | 03:20 PM
  #5822
4DGS's Avatar
Once I have my 18s rebuilt I should be about 11 +5 and 10 +0
Old Jun 29, 2012 | 03:48 PM
  #5823
4DGS's Avatar
These would be sick on a sedan...
Some spacers and camber, good sized lips, not a lot of work!
http://www.vrwheels.com/work-vs-p-4648.html
Old Jun 30, 2012 | 12:55 AM
  #5824
MPG35fiend's Avatar
Originally Posted by Gorg3ou5
i almost got those wheels! super clean sedan.
Old Jul 5, 2012 | 04:04 PM
  #5825
IPGSEDAN's Avatar
Originally Posted by vtec
my setup right now
Props to Marcus for these pics!
225/35/19 on a 9.5 +17
235/35/19 on a 10.5 +19
Does anyone know how around how much camber I need to make something like this work? BEEEAAST!!
Old Jul 5, 2012 | 04:06 PM
  #5826
Gdup35sedan's Avatar
ENVautoDetailing.com
-2.5 to 3 up front
-4 to 4.5 in the rear.
Assuming you're as low as Vivek was in that picture (he's on bags now)
Old Jul 5, 2012 | 09:52 PM
  #5827
MPG35fiend's Avatar
damn seems like everyone on the over there is getting bagged.... time to look into it myself!! what type of bags has the best settings?
Old Jul 6, 2012 | 04:30 AM
  #5828
dragnby's Avatar
hey guys i need your help. before i order my coilovers what spring rates are you guys running for a pretty aggresive fitment? my wheels will be 20x9 20x11 +15 but im probably gonna use a spacer to get a little poke. just curious what some of your spring rates are for an aggressive set up.
going with BC coils. if that matters. thanks guys!
Old Jul 6, 2012 | 04:35 AM
  #5829
4DGS's Avatar
Viveks been on air for.... like 2 years?
Most go with 12/10 for ride comfort. but I think they came to the conclusion that they don't go as low as 10/8, so check that out before you make any decisions. I'd go 12/12 if possible.
As for the wheels... you know what you're getting into making them fit? Not exactly a bolt on process for 11 +15. The front you'll want at least a 15mm spacer.
Old Jul 6, 2012 | 08:21 AM
  #5830
shawndon's Avatar
I have the 12/10 BCs and 4DGS is right, they don't go low as low as 10/8 spring rates. At least the fronts don't. If I had to do it over, I'd do Stance GR Pro coils. In fact I'll most likely switch to stance coils at some point. The ride is still not harsh with the higher spring rates but in order to get the fronts down to where I wanted I had to take the preload off the front springs which I didn't want to do. And that's with 20in wheels.
Old Jul 6, 2012 | 11:28 AM
  #5831
dragnby's Avatar
Thanks for the info. Yea I know it's gonna be some work for fitment but I'm ready hah. Thanks again for the info!
Old Jul 6, 2012 | 12:49 PM
  #5832
DTRUONG_112's Avatar
I should be receiving my stance gr+ today, with 12k/12k spring rates.
Old Jul 6, 2012 | 04:44 PM
  #5833
4DGS's Avatar
Ok, I thought so, but my experience with BCs is limited. They really need to correct that.
Stance is the way to go, best coils on the market for the money.
Old Jul 6, 2012 | 05:26 PM
  #5834
shawndon's Avatar
I want Stance coils do bad. I can't stand the way the fronts are. I wish I had known that those higher BC rates would be that way. If remember, I think there is another member with 13k up front. Hopefully he'll chime in.
Old Jul 6, 2012 | 05:29 PM
  #5835
Shanes_G's Avatar
my stace gr+ are on the way fresh from japan. got the rear springs beefed up also.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
