OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Feb 1, 2013 | 08:10 AM
  #6796
Chris C.'s Avatar
Originally Posted by JosansG35
That's what the sedan is for! To have your hoes riding with you!
fixed.
Old Feb 1, 2013 | 12:35 PM
  #6797
The Stimulation's Avatar
Of course I go up driveways! The only driveways I don't go up are the ones that have a really sharp angle at the top and I know I will get stuck and my rear will be floating lol It's happened before haha
I gotta cruise with you one day man...I wasn't that low and I mangled the crap out of the bottom of my car. Broken o2 sensor plugs and wiring, oil pan scraped, f*ck downtown LA and a few streets near me that are similar to there. Perhaps I drive too fast.
Old Feb 1, 2013 | 12:38 PM
  #6798
TORETTO's Avatar
I thought the oil pan was fairly safe sitting above other things that take most of the hits?
I scrape everything in mine and I still tackle driveways every now and then. Of course at this point, I know which driveways I can make and which ones I can't.
Old Feb 1, 2013 | 02:33 PM
  #6799
hello1's Avatar
question
Hello,
Sorry to trouble you guys. I had a quick questions regarding shock clearance and haven't seen any posts relating to it. Any of you with low offset wheels running true coilovers in the rear? I am trying to figure out the clearance from inner lip of wheel to true coilover. I have seen a post of a 10.5 +29 hitting coilover collar at full lowered height, but was wondering if that was on true rear coilover. My dilemma is 10.5 +26 and if spacers are needed to clear true coilovers, btw i would like to leave rear fender unpulled, flat rolled but no pull. Any help would be greatly appreciated. Thanks in advance!
edit*
from what i have researched and my calculations, i saw that someone had a10.5 +40 offset and stated they had roughly around 10mm of clearance from collar, not sure if oem style or true coilover
so if 10.5 +26 that would mean I would have 24mm of clearance from collar, roughly one inch. for every degree of camber, you lose about 4mm inward (dependent of length of arms etc. but roughly) so after about 3.5 degrees of camber, there should be clearance of 10mm (24mm -4mm*3.5)
so if looking at those numbers, not sure if accurate or not as I don't have any test fitment available will 10.5 +26 clear true coilovers?
Thanks,
Hello1
Old Feb 1, 2013 | 07:58 PM
  #6800
I didn't have a front sway bar at the time.
Old Feb 2, 2013 | 05:01 AM
  #6801
JosansG35's Avatar
Lol I hit everything too but my sway bar just demolishes everything in its way. One of my o2 sensors ripped recently too lol As far as dtla goes, u need to knoe which streets to take cuz most are really shltty
Old Feb 2, 2013 | 01:33 PM
  #6802
Which o2 sensor? I have an extra driver side one that goes into the cats if you need it. Yeah I'm not too familiar with dtla and night driving fml. I know going to hollywood taking forest lawn then instead of taking the 101 taking la cienaga by making a left somewhere on the left lane theres a huge pot hole. Even with my meaty tires and not too low of a drop it's painful. Been like that for months and I keep forgetting about it.
Old Feb 2, 2013 | 03:58 PM
  #6803
JosansG35's Avatar
I'll take it! That's the one that ripped off. It kinda broke a piece from the connection that connects to the car tho... uh oh
Old Feb 4, 2013 | 03:22 PM
  #6804
2006mt's Avatar
Originally Posted by hello1
Hello,
edit*
Thanks,
Hello1
I am running 19x10.5 et33 w/ a 255/35 tire and tein Basic coilovers. The inside lip of my wheels do rub the shocks when going up very steep driveways.
Old Feb 4, 2013 | 06:24 PM
  #6805
How's 40 bucks sound? Think I paid 50 or 60...ended up not needing.
Old Feb 4, 2013 | 08:48 PM
  #6806
JosansG35's Avatar
hit me up on fb
Old Feb 4, 2013 | 11:45 PM
  #6807
Scrildo's Avatar
How are you guys running these aggressive *** setups and not chewing up front tires???? I'm putting my stock suspension back on until i get a set of spc front a arms. There are some sweet cars in this thread i cant wait to one day be on the same level as you guys.
Old Feb 4, 2013 | 11:47 PM
  #6808
TORETTO's Avatar
maybe we do chew up tires, we just don't give a damn.
#yolo #swag #cray #becauseflushcar #yoloanddontgivea****swagalldaycraycraynomsayin
Old Feb 5, 2013 | 12:04 AM
  #6809
Scrildo's Avatar
Lol ok thought it was just me
Old Feb 7, 2013 | 02:27 AM
  #6810
aerry408's Avatar
Hopefully my car fits in this thread now
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
