OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Mar 6, 2013 | 05:37 PM
  #6856
Quote: He's on stance and swift springs now
Just Stance GR+ for now, didn't get the swift springs yet. I have the helper spring for the rear. Will also get the helper spring for the fronts, so in they will end up being Stance GR+ Pros with Swift Springs.
Reply 0
Mar 6, 2013 | 05:39 PM
  #6857
Quote: If you have them installed now. Do the Stance coils give you what you're looking for? Hopefully so. In my case BCs just don't cut it for wanting to ride low. Even with stiffer rates. I'm not too surprised you switched. Given you were already running the dampeners on full.
Stances are way better for slammed cars for sure! I have them at 3 clicks from full stiff and they are stiffer than my BCs were at full stiff (although I do have stiffer spring rates now). I can also run toe arms now given they are true rears, which I really needed to given the amount of camber I am running out back.
Reply 1
Mar 6, 2013 | 05:42 PM
  #6858
Quote: Do you have high rate springs or do the lips clear the fender? Or both
Spring rates are 12K/8K (true style). Outside edge of the fender barely scrapes the inside of my rear fender on large dips and under full compression. Up front the wheel clears no prob, tires rub when I turn.
Reply 1
Mar 8, 2013 | 01:16 AM
  #6859
Reply 4
Mar 8, 2013 | 01:31 AM
  #6860
damn low low
Reply 1
  #6861
Wow!!!!!!!!!!!!!!
Reply 1
Mar 8, 2013 | 01:51 AM
  #6862
Josan, The second pic looks crazy. I had that as my ride height for 5 minutes and I know you cant turn LOL. Looks so sick though.
Reply 1
Mar 8, 2013 | 10:13 AM
  #6863
dumpeeeeeed lol wow
Reply 0
Mar 8, 2013 | 10:20 AM
  #6864
josans are you bagged?
Reply 1
Mar 8, 2013 | 02:16 PM
  #6865
Quote: josans are you bagged?
Haha No the car is static. I was working on the car and I ended up dropping it way more than I wanted. Like gtrefever said, you cant' turn haha
Still working on the perfect stance though.
Reply 1
Mar 9, 2013 | 01:53 AM
  #6866
lowest sedan??
Reply 1
Mar 9, 2013 | 12:59 PM
  #6867
I remember when Shane installed my F&F coils. I think fronts still had room to go but I couldn't even pull out this garage. A half or an inch concrete difference had everything scraping. Couldn't turn the wheel at all. I swear I felt like I was in a CRX or some sh*t. Looks super sick tho
Reply 1
Mar 9, 2013 | 01:26 PM
  #6868
Needs to be on 18s to be the lowest Sedan I think But yeah Jeremie you can count on one hand the number of folks as low as you.
Reply 1
Mar 9, 2013 | 02:13 PM
  #6869
Quote: Needs to be on 18s to be the lowest Sedan I think But yeah Jeremie you can count on one hand the number of folks as low as you.
Just kidding about being the lowest, cause when blain was on 18s that was ridiculous.
Reply 0
Mar 9, 2013 | 08:33 PM
  #6870
Lower it for sure huh guys?
Reply 0
