OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old May 10, 2013 | 11:17 AM
  #7021
gtrefever's Avatar
Stick to 18s and nothing lower.
Old May 12, 2013 | 09:50 AM
  #7022
NISMonly's Avatar
anyone here running the Stillen adjustable rear toe links? Im trying to piece together my suspension overhaul and was hoping these get my toe back in spec while being lower and more cambered.
My current alignment for toe is in spec with -4.5ish degrees rear camber, however i really want to get it back to -6.5 degrees rear camber, however the toe was wayyy out and couldnt bring it back in with just the toe bolts
Old May 13, 2013 | 01:41 AM
  #7023
JosansG35's Avatar
Take it to a shop. They got my toe back to spec with only toe bolts and the camber is at -4.8 degrees.
Old May 13, 2013 | 12:58 PM
  #7024
NISMonly's Avatar
my toe is in spec and aligned for now with just toe bolts. However i wanted more negative camber but at -6.7 degrees the toe couldnt be brought back in.
I have decided to eventually switch to Stance True style coils w/ upgraded spring rates then use a toe arm to replace the spring bucket and be able to straighten the toe out
Old May 13, 2013 | 01:36 PM
  #7025
JosansG35's Avatar
Well then do it. Any toe arm should do the trick.
Old Jun 12, 2013 | 04:23 PM
  #7026
usikan2237's Avatar
would i be able to fit 19x10+ 10 and 19x11 +10 without crazy camber?
Old Jun 12, 2013 | 07:28 PM
  #7027
g35loving's Avatar
Anything is possible. If you can do body work or can roll fenders then yes all day long it can be done with no crazy camber
Old Jun 12, 2013 | 07:34 PM
  #7028
mj_39's Avatar
^ NO way those will fit without doing some work, you will still have to run a decent amount of negative camber
Old Jun 12, 2013 | 07:35 PM
  #7029
mj_39's Avatar
repost
Old Jun 13, 2013 | 12:31 AM
  #7030
JosansG35's Avatar
Thumbs up
Yes you can. I'm running 10 +0 and 11+0 and my camber is at -5 front and -4ish rear
Old Jun 13, 2013 | 02:00 AM
  #7031
NISMonly's Avatar
new setup... riverside aldstadts and bc racing coils, idk why the rears dont go lower? I got the true style coils with 12k/10k springs. Drivers side rear is slightly lower ~.25"
wheel specs - 18x9+11 front and 18x10.5+16 rear
tire specs - 215/40/18 front and 235/40/18 rear
Old Jun 13, 2013 | 02:41 AM
  #7032
4DGS's Avatar
They bottom out the struts, if you wanna get low on true coils you need Stance coils.
Old Jun 18, 2013 | 02:11 PM
  #7033
Z's G's Avatar
I need a little help please. I have a 04 g35x I am running 20x9.5 front 20x10.5 rear. If I run a cooper 245 35 20 on the front do you know what I have to run on the back? I know straight up a 245 35 20, 275 30 20 would be within the 3% range for AWd but the stretched on the back is throwing me off. Thanks for the help. Would a 255 30 20 work on back?
Old Jun 18, 2013 | 03:38 PM
  #7034
JosansG35's Avatar
are you just worried about traction or are you trying to make these wheels fit? maybe MPG35Fiend could help you out. He's the one with the X on bags.
Old Jun 18, 2013 | 03:52 PM
  #7035
Z's G's Avatar
I'm worried about traction coming on. I know I can't do a 275 30 it would be to wide.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
