OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jul 31, 2010 | 09:57 PM
  #1396
CandlestickPark's Avatar
ill Sedan
Originally Posted by BlkSedan4me
^ i'm aware. I meant before he put the spacer, wondering if he rubbed before the spacer and if he didn't rub if his fenders were rolled at all. because i have the same tire size and putting 10mm spacers on my 19"s would put me at only 2mm more lower offset than his LMGT4s without spacers
Oh, I was thrown off cause you said 8.5 +35 but his wheels are 8.5 +25.
  #1397
ill Sedan
Vivek that is beyond aggressive....hehe.
Old Jul 31, 2010 | 10:01 PM
  #1398
4drmadness's Avatar
yea lets see if a 15mm can clear my bbk, if not i will have to camber a lot
Old Jul 31, 2010 | 10:09 PM
  #1399
Matzo Ball's Avatar
I had a very mild roll when I had the OEM Rays and never came close to rubbing. The 10mm added more poke than I intended. Once I get the camber adjusted we shall see if I stick with the 10mm. I do love the poke it will give
Originally Posted by 4drmadness
This is what a 25mm spacer looks like on a
8.5 -12 (-37)
Thank is not "poke," that is "sticking the **** out"
/thread!!!
Old Jul 31, 2010 | 10:23 PM
  #1400
ill Sedan
Oh your wheels won't clear the Alliance BBK. Hopefully a 15 will clear. Even with a 15 I think you'll have to add some camber. When will the BBK be on, can't wait to see!
Old Jul 31, 2010 | 10:28 PM
  #1401
Matzo Ball's Avatar
marcus, how flat were you rolled and how low when you ran 255s? Getting an alignment tues so I have less camber, proper poke, no rub. Plus I know my caster and toe need a huge adjustment.
Old Jul 31, 2010 | 10:30 PM
  #1402
ill Sedan
^I was rolled very flat. Basically as flat as you could go until you started to do a pull.
Old Jul 31, 2010 | 10:35 PM
  #1403
Matzo Ball's Avatar
Pretty much where I am now. But you had 8mm more than currently do, right? Wondering if a 5mm spacer would be better than a 10mm.
Old Jul 31, 2010 | 10:43 PM
  #1404
ill Sedan
^Yeah mine was about 8mm more aggressive than your setup. Tire brand will make some difference, but not that much I don't think. What camber are you at right now? Pics of how its sitting?
Old Jul 31, 2010 | 10:49 PM
  #1405
SN00P's Avatar
CLUB MODERATOR
i need to find someone around here to roll my cut fender i have .... hell i may just try to do it myself ... heat gun and what is the best thing to roll what i have left .... ???
Old Aug 1, 2010 | 01:06 AM
  #1406
NjMatteSedan's Avatar
oh my mistake. I meant to type 8.5 +25. I was gonna see if i could get away with mine without a roll but i guess i'm gonna have to
Old Aug 1, 2010 | 02:47 AM
  #1407
The Stimulation's Avatar
As Marcus said, even with a 15mm you'll have to camber. Get the SPL v3's or Cusco and modify them like I did, unless you can find 350 Evo arms.
Where you're at now you would need to dial in another 5-7 degrees of camber to make it clear.
Old Aug 1, 2010 | 03:11 AM
  #1408
4drmadness's Avatar
I have ichiba front camber kit, so ill try modifing them and maxing out the camber, damn low disk wheels
Old Aug 1, 2010 | 04:19 PM
  #1409
Dranom's Avatar
show some love for our homie Marcus!
vote
http://www.stancenation.com/forum/vi...php?f=5&t=1066
Old Aug 1, 2010 | 04:21 PM
  #1410
Matzo Ball's Avatar
I will get some. Odd thing is, my car now sits LOWER in the rear since the spacer and camber arm install. When from 1 finger gap to almost .5 -.25 finger gap Looks odd. More I think about it, I think the caster may be way off since the wheel is not quite centered in the well. Higher degree of caster would probably result in less verticle ride height.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
