History of my 2003.0 G35 Sedan, in true nerd style.
Old Dec 18, 2010 | 09:58 AM
  #406
Swivel's Avatar
Moderator
Super-nice photo, Ashley, and the car is lookin' great!
Old Dec 18, 2010 | 10:14 AM
  #407
SN00P's Avatar
CLUB MODERATOR
LOL i know i know !! i love my photog stuff im set for a while
Old Dec 18, 2010 | 10:28 AM
  #408
NFSP G35's Avatar
? = 2B || !2B
^^Thanks Wayne.
Old Dec 19, 2010 | 10:50 AM
  #409
G35Papa's Avatar
Originally Posted by swivelhips
super-nice photo, ashley, and the car is lookin' great!
+1 :nod:
Old Jan 22, 2011 | 09:59 PM
  #410
NFSP G35's Avatar
? = 2B || !2B
E-Fan upgrade in the works! ---> http://www.nfspmotorsports.com/forum....php?topic=382
Old Jan 22, 2011 | 10:54 PM
  #411
NFSP G35's Avatar
? = 2B || !2B
And also, projector retro-fit ---> http://www.nfspmotorsports.com/forum....php?topic=384
I have so many little projects going on, I'm losing my mind
Old Jan 22, 2011 | 11:22 PM
  #412
Swivel's Avatar
Moderator
Stop chewing your nails.
/Dad
Old Jan 22, 2011 | 11:26 PM
  #413
NFSP G35's Avatar
? = 2B || !2B
^Yeah, IKR? Only a LOT
Old Feb 2, 2011 | 08:53 PM
  #414
NFSP G35's Avatar
? = 2B || !2B
Update on the e-fan mod:
Just got done wiring the control board.
Hooked it up to my 12V bench supply and tested everything with a voltmeter.
All is well!
Pic -> http://www.nfspmotorsports.com/forum...d=1935;preview
Now, all I have to do is roughly calibrate the thermostat switch by mixing boiling and cool water until I get it to click at the right temperature.
I'll then install the control board in the car, but leave the clutch fan in place and temporarily wire a light in the cabin so I can monitor when the fan would be engaging and disengaging.
After fine tuning the thermo-switch, I'll swap the clutch fan for the electric fan
Old Feb 2, 2011 | 08:54 PM
  #415
thescreensavers's Avatar
Mr.202?
Sweet! Now you are getting some pawah!
Old Feb 2, 2011 | 08:59 PM
  #416
NFSP G35's Avatar
? = 2B || !2B
Update on projector retrofit:
I got the proper HID kits in from DDR the other day, and swapped them into the projectors and powered them up off of my 12v bench power supply.
Worked nicely, but I noticed the projector with the OEM lens actually had a better cutoff and light dispersion than the one that I swapped for a clear lens. So I'll be swapping back to the OEM ones.
I'm guessing it's because the clear lenses I had were from a car with halogen projectors, not HID.
I also test-fitted the H1 3000k in a extra G35 headlight I have in my room.
Even though it's a halogen light, it doesn't glare when you put the HID in it.
I was surprised that the light dispersion looked pretty even.
That being said, I may end up doing something different with the top lights
Old Feb 2, 2011 | 10:37 PM
  #417
Mr.202?
^ Look at dem 6039421111
keyword!
Very nice, Cant wait to see finished product!
Old Feb 6, 2011 | 03:20 PM
  #418
Mikhail21's Avatar
Originally Posted by NFSP G35
^Yep. He's right.
However, I used a very different method for the interior parts vs what I did on the wheels and grill. Also, the grill has flat clear, and the wheels don't.
Im new to this modding thing as well as new to the owning of a G35..How did you go about painting the grill, rims, side mirrors?
Old Feb 6, 2011 | 03:59 PM
  #419
NFSP G35's Avatar
? = 2B || !2B
keyword!
^I have no idea what you're talking about
Anyway... E-Fan update:
I just mounted the controller board and put the temperature-switch probe in. Also swapped the thermostat to the newer 170deg one.
Next step will be doing a little wiring, and then once I verify everything is working as expected, on to the actual fan swap
Old Feb 7, 2011 | 09:26 AM
  #420
NFSP G35's Avatar
? = 2B || !2B
^Replied to your PM.
Basically, the Grill is all about prep work (sand with 400grit, wipe thoroughly with alcohol) and priming (DupliColor self-etching primer, sand with 800 grit)
I also did a matte clear coat on top of the black. The grill has held up really well.
