The "Look what I made/installed/modified today" thread.
Thanks man, I wonder why the rears have a bleeder on the bottom??
That said once I do get around to going FI in the future, my FMIC will definitely be polished. In the mean time I may build an ARC style oil cooler, polish it and run it in the large center opening of the bumper.
"To properly bleed the brake system, begin with the caliper farthest from the master cylinder. Bleed the outboard bleed screw first, then
the inboard. Repeat the procedure until all calipers in the system are bled, ending with the caliper closest to the master cylinder. If the
caliper is fitted with bleed screws on four corners, make sure the bottom bleed screws are tight. Only bleed from the top bleed screws."
Here are the links to the manuals Tim:
Fronts (w/14" rotors) - http://wilwood.com/PDF/DataSheets/ds547.pdf
Rears (for later
) - http://wilwood.com/PDF/DataSheets/ds546.pdf
FI or don't even think about it. A nice ARC oil cooler would be acceptable though
My guess is they are used to either swap out fluid (open bleeders and let the fluid drip out) or the calipers are used on other cars (besides Nissan). You can flip the caliper to the right side of the rotor for other cars.
^I can tell you've never bled brakes before
i have, just my attempt at humor and laziness bundled into 1. teh intranetz doesn't capture the true essence of my dry sense of humor
