The "Look what I made/installed/modified today" thread.
Old Sep 12, 2011 | 08:34 PM
  #1426
SN00P's Avatar
CLUB MODERATOR
up date !!!
ill be installing everything this weekend !!!
both coolant tank and PS tank as well as all the slip over braided lines i bought with all the red clamps from earls :-)
o yea i just made a purchase from SxExCx
Old Sep 12, 2011 | 08:49 PM
  #1427
Blue Dream's Avatar
I drove ttrank's car solo
Ash, thanks for the link to the chrome bolts. How do we figure out how long each bolt we need is w/o taking them out and measuring? Also, how would you check torque specs with the allen bolt heads?
Old Sep 12, 2011 | 09:08 PM
  #1428
SN00P's Avatar
CLUB MODERATOR
g35mods.com ^^^ google it and look up how to install plenum spacer ... there is a awesome pic and paragraph telling you the correct way to torque each one down and the correct pattern around the plenum buddy... i guess i answered your question ... i have an allen head adapter that going on my torque wrench
Old Sep 12, 2011 | 09:20 PM
  #1429
Blue Dream's Avatar
That's the answer I was looking for. I guess I could contact Tony at MD for the bolt sizes on the 5/16" spacer.
Old Sep 12, 2011 | 09:30 PM
  #1430
NFSP G35's Avatar
? = 2B || !2B
You have a plenum spacer?
As far as torque goes, torque it by hand with an allen wrench turned the long way (the low torque way) or a hand screwdriver with an allen tip, and you'll get it just about perfect.
Wouldn't hurt to throw a little lock-tite on the end of the bolts.
Old Sep 12, 2011 | 09:37 PM
  #1431
Blue Dream's Avatar
Yes I have the 5/16 mentioned above. I think your idea with the allen wrench is a good one. I've had my spacer off and on several times and I've installed several here on other people's cars so I have a good idea of how they feel when they get tightened just right. Still might go by allen wrench adapters for the torque wrench, that sounds magical.
Old Sep 12, 2011 | 10:10 PM
  #1432
NFSP G35's Avatar
? = 2B || !2B
^Just make sure it's an inch-lb torque wrench. They're spec'd for very little torque.
If you have a 5/16, the sizes you want should be
10 or 11 (can't remember for sure) m6x1.0 35mm
3x m6x1.0 50mm
4x m6x1.0 70mm
(IIRC)
Oh, also... if you pick up a random assortment of m6x1.0 25mm and m6x1.0 16mm that will do most of the other bolts around the fenders/etc... and the 4 big ones (12mm socket size) that hold the radiator support are m8x1.25 16mm
The two nuts on the plenum are m6 and the 6 nuts (3 each side) for the top of the strut towers are m8x1.25
Old Sep 12, 2011 | 10:12 PM
  #1433
Blue Dream's Avatar
Yup on the in/lb.
Thanks for the bolt info, I love this forum.
Old Sep 12, 2011 | 10:14 PM
  #1434
NFSP G35's Avatar
? = 2B || !2B
and also, 4x m6-1.0 60mm for the throttle body
Old Sep 12, 2011 | 11:11 PM
  #1435
Chief.Crappin.Squirrel's Avatar
damn.....i will be ordering some now. where can i find those fancy washers??
Old Sep 12, 2011 | 11:28 PM
  #1436
NFSP G35's Avatar
? = 2B || !2B
^Like mine? You can't, that was the custom part.
For the socket-head ones, that same site I posted does have some really pretty chrome flat-washers... if you want color though, about your only remaining option is this site: http://www.galleryfresh.com/6.html but be forewarned, they're hella-expensive, and they don't have a kit specifically for the G (Z kit is close, but there are bolts it has that you won't need, and bolts you'll need that it doesn't have)
Old Sep 12, 2011 | 11:37 PM
  #1437
damn...i have a few gallery fresh ones but i thought they went out of business?
Old Sep 12, 2011 | 11:40 PM
  #1438
NFSP G35's Avatar
? = 2B || !2B
^Not that I'm aware of... but IDK, never ordered from them
You could always get password JDM: http://passwordjdm.com/PasswordJDM-E...ries-C455.aspx
But they're even more expensive (and also not JDM )
Old Sep 13, 2011 | 01:31 AM
  #1439
Gdup35sedan's Avatar
ENVautoDetailing.com
Installed these bad boys with Z1 Brackets last wednesday. Full pics will be up after the WFC meet this weekend as well as pics of another surprise I wont reveal until those pics are posted!
Old Sep 13, 2011 | 01:36 AM
  #1440
CandlestickPark's Avatar
ill Sedan
Winning!
