custom exhaust build
Old Mar 2, 2011 | 04:50 PM
  #31
kennymo's Avatar
Originally Posted by importroller
key words there are "almost never"
these cars can run a true dual exhaust n/a and be just fine if you do things correctly. I didn't read every post, so i'm not 100% positive if this has been addressed or not. but what diameter is the piping on the exhaust?
2.5
Old Mar 2, 2011 | 04:59 PM
  #32
importroller's Avatar
on these motors N/A a 3" single exhaust works great with dual output. now if you are running dual pipes at 2.5" each, you basically just opened it up to a 5" exhaust which will just make the car louder, kill your gas mileage, and cause you to lose power. you need your exhaust velocity to match your engine output, and if you are a basically stock VQ motor, 5" is way too much air flow
Old Mar 2, 2011 | 05:04 PM
  #33
Jeff92se's Avatar
Red Card Crew
Um, the OP is talking about using two pipes. The pictures show this. and thoughout the thread, the discussion is about dual exhaust.
BTW, stillen uses 2.5" pipes and there's dyno proof of the gains.
Also a 5" single pipe doesn't equal two 2.5" pipes. The math isn't that simple.
Old Mar 2, 2011 | 05:06 PM
  #34
kennymo's Avatar
thats what i was thinking.
Old Mar 2, 2011 | 05:17 PM
  #35
Stillen also uses A LOT of R&D to make those sizes work with the motor. Stillen also is not a true dual either. stillen also has a x-pipe that splits again to duals that creates the correct exhaust velocity. It wasn't something they just pieced together in a weekend and said here you go. it took time and quite a bit of testing to get the correct combo. The math I gave was what you would call the K.I.S.S. method of math
Old Mar 2, 2011 | 05:28 PM
  #36
Jeff92se's Avatar
Red Card Crew
Umm it's not rocket science. You can't say using 2 x 2.5" pipes is way too big and then state it's okay if you use "alot of R&D". No amount of R&D will make an improperly sized exhaust perform well.
Old Mar 2, 2011 | 05:46 PM
  #37
when you merge the two banks into that x pipe it slows down the exhaust velocity and combines in to then utilize the split back to 2.5" again. Thats why i mentioned earlier about "true dual"
But hey, I'm done arguing with you, Kenny good luck with your project. Hope it works out the way you want it to.
Old Mar 2, 2011 | 05:50 PM
  #38
Jeff92se's Avatar
Red Card Crew
I'm X pipes don't slow the exhaust gases down, it speeds it up.
You should stop arguing with me because you are going to lose badly
http://www.streetdirectory.com/trave...ore_power.html
Although X-pipes are essential for race cars, adding this modification to a stock car can be a good idea for many reasons – increased power, fuel economy and less noise inside the vehicle. This type of aftermarket performance part is something you can either purchase or have custom-made for you by a good muffler shop. Installation is simple enough for the at-home pro, and the result will be well worth the effort.
◦The Evolution of the X-Pipe
To understand the importance of the X-pipe in relation to improved performance and power, you have to know about its roots. The X-pipe is really the offspring of the H-pipe design, which was first conceived in the 1960s by the major American car manufacturing companies at the time. Duel exhaust pipes for V-8-powered vehicles are very noisy, as there is no sound wave cancellation between the 2 separate four-cylinder engines and unconnected exhaust systems. Engineers were looking for a way to cut down on interior noise levels and improve the engine's power. They realized that running a balance tube between the two branches of exhaust pipe would work to broaden the torque curve (thus improving engine performance) and dissipate sound resonance in the exhaust system.
In the 1990s improved technological advancements made it possible to construct an exhaust pipe that, instead of connecting by means of a balance pipe at a severe 90-degree angle, could unify the two branches of pipe to create a flow of exhaust in one direction. Now X-pipes are being manufactured for popular performance cars, usually off-road versions minus catalytic converters, but you can also find them in legal models fully equipped with proper emissions equipment. Performing an X-pipe mod is an option that you should consider.
◦Why X over H?
It has been proven time and again that the X-pipe design is more efficient than the H-pipe. Various tests have shown that for multiple cylinder engines the X-pipe outperforms H-pipe exhaust systems, especially as rpm increases, providing both better torque and power. Unified exhaust pipes work most efficiently with multiple cylinders because of the scavenging effect. With exhaust X-pipes the almost seamless connection between the two exhaust pipes allows sequential firing cylinders to salvage any spent exhaust gases from the combustion chamber more efficiently and creates more room in the cylinder for a fresh intake of undiluted fuel and air. When you have two exhaust pipes, as the velocity in one header tube increases, the pressure in the adjacent tube is lowered causing the exhaust to be sucked out of that cylinder. X-pipes are simply better at doing the job, especially at higher speeds.
◦Installing Exhaust X-Pipes
This is a simple mod that almost anyone can perform successfully. Most companies produce exhaust X-pipes that are simple bolt-ons that can be installed in less than an hour using the usual hand tools.
If you own a vehicle that doesn't have an X-pipe available, it is possible to have a custom X-pipe assembled for you. A muffler shop can construct it by taking an X-pipe union and bending up some exhaust tubing until it fits. If you decide to make your own exhaust X-pipe from scratch, so-to-speak, remember to place the X-pipe union as close to the rear of the vehicle as you can to increase the power.
◦A Brief How-To
To install exhaust X-pipes, first begin by positioning the passenger-side header pipe in place and tightening it before moving on to the next step. Make sure it is secure. Now, fit in the actual X-pipe along with the driver's side header pipe. Remember that the long leg of the X must go toward the front driver's side of the car. Now it's time to fit the pipes of the X into position and loosely attach them to the after-cat system. You might have to adjust how the after-cat is hanging for proper tailpipe positioning and tuck up the X-pipe square. On some vehicles the tranny crossmember has an exhaust hangar - if this is the case you can tack the hardware onto the pipes. Tighten the bolts and tack-weld the junctions at the X. Check everything one more time before removing the X-pipe and welding the full length of the junctions. The assembled unit now needs to be bolted back into position - simple as that.
All in all, with exhaust X-pipes torque and power will increase resulting in fast acceleration, improved fuel economy and a nice quiet ride. The difference is noticeable with the installation of X-pipes on a V-8 engine vehicle - interior noise is reduced considerably because you don't hear the firing impulses of 2 four-cylinder engines, but instead hear the noise of all 8 cylinders blasting out of both pipes at once.
Old Mar 2, 2011 | 05:51 PM
  #39
Jeff92se's Avatar
Red Card Crew
◦Why X over H?
◦A Brief How-To
Old Mar 2, 2011 | 06:00 PM
  #40
G35SedanGrn's Avatar
Good luck kenny, i wish our cars came dual exhaust stock, and even if you fail it's a learning experience.
Old Mar 2, 2011 | 06:38 PM
  #41
Oldie but a goodie
and with that, I'm out!
Old Mar 2, 2011 | 06:41 PM
  #42
Eric@TCGMiami's Avatar
I haven't read anything other than that and I can tell the rest of your post will be invalidated.
X pipes increase scavenging effects thus making the exhaust gases move faster.
Old Mar 2, 2011 | 06:42 PM
  #43
Jeff92se's Avatar
Red Card Crew
importroller
You want to discuss facts? Fine, post evidence that backs your claim up.
Want to post like the child in the picture? Then yes, stay out of the discussion and let those that know what they are talking about do so.
Old Mar 2, 2011 | 06:46 PM
  #44
My .2 cents
Go FULL 3 inch
If I had an aluminum welder, I'd make the exhaust all aluminum (weight savings ftmfw).
Old Mar 2, 2011 | 06:57 PM
  #45
kennymo's Avatar
You almost never want to run a NA exhaust w/o some type of cross over.
how come?
