UnderNothing's G35 Sedan Build
I'm guessing you also have an auto so all you do is take off the center console, take out the screws that hold on the little aluminum plate thing around the shifter. cut the bottom of the Crown bag and put it around the plate. screw the plate back down and reinstall the console. pull the drawstrings tight around the shifter and tie em so they don't come loose.
laksjd84
Jul 24, 2015 05:12 PM
