LED Interior / Exterior Video
Old Feb 6, 2008 | 09:33 AM
Mrpeeng's Avatar
I installed some LEDS last week and made a video for a friend who wanted to see how bright they would be so I thought I'd share that with anyone who would also like to know.
My configuration are as follows
Front Map - 12 LED x 2
Rear passenger - 5 WLED (W = wide angle) x 2
License Plate - 1 High Powered LED x 2
Front Door - 6 LED x 2
Trunk - 12 LED (Same as the front map)
I left the vanity mirrors for now.
http://www.youtube.com/v/VZx5elyt3g4
Old Feb 6, 2008 | 04:33 PM
remedy00311's Avatar
if you dont mind.. where'd u purchase the license plate LED from?
Old Feb 6, 2008 | 04:35 PM
Mrpeeng's Avatar
superbrightled.com
Old Feb 6, 2008 | 05:09 PM
tried browsing the site.. is there any way you can lead me to the correct link?
Old Feb 6, 2008 | 05:11 PM
O HELLA OEM's Avatar
nice
Old Feb 6, 2008 | 10:32 PM
Mrpeeng's Avatar
Sure, Click on the link below and scroll all the way down to the bottom. The light I selected is the 3rd one from the bottom on the first page. Look for "WLED-WHP Pure White High Power".
http://www.superbrightleds.com/cgi-b...gi?product=CAR
Old Feb 7, 2008 | 10:22 PM
John2.5RS's Avatar
So how much did all those LED's cost?
Old Feb 8, 2008 | 08:15 AM
Mrpeeng's Avatar
50 and change.
Old Feb 22, 2008 | 03:11 PM
was the license plate bulb hard to change? my bulbs just came in today and wanted to know what you needed to do for the change? did you need to remove the rear bumper?
Old Feb 22, 2008 | 03:15 PM
CarFreak's Avatar
All you need to do is squeeze a clip and pull the bulb covers down. Then twist the bulb out and replace with the new one. Takes literally 2 minutes to change both bulbs.
Old Feb 22, 2008 | 03:17 PM
Stealthcords's Avatar
They're very easy to change. Look above your license plate - you will see two plastic pods (the lights are in them). On one side of the pod will be a white tab, simply press that in and pull the pod. The pod will come out and you simply twist the bulb out. It takes 5-minutes max.
Old Feb 22, 2008 | 11:15 PM
SVLRx's Avatar
anyone changed the rear turn signal bulb? When i got my car i thought it was strange that the outside of the light (brake light) is LED, but when you turn on your turn signal they flash incandescent....
NailBomb
Oct 28, 2015 07:53 AM
TNRocker
Sep 21, 2015 08:36 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
gatorglaze
Sep 10, 2015 12:03 PM
