Teaser Project - True 3K HID Fog Kit
Old Aug 29, 2010 | 09:15 PM
  #121
pattyballs's Avatar
Im thinking bout going the budget way, i think the 07-09 sedans look sick with foglights in the lower grills, should have came OEM like the 2010's. what did you use to cut the plastic lower grills?
Old Aug 29, 2010 | 09:33 PM
  #122
mishmosh's Avatar
I would think a hole saw kit or dremel would work just fine.
Old Sep 23, 2010 | 10:44 PM
  #123
djfarhan's Avatar
how did u and how hard was it to carve those holes out for ur yellow fogs?
Old Sep 25, 2010 | 04:51 PM
  #124
kmuniz78's Avatar
I certainly didn't attempt it. There is little room as is behind the fake sills due to the water resevoir. The shop went in under the car actually. I believe they just dropped the engine bay cover and worked through that way. The lights are mounted to the bottom of the bumper brace I beleive.
Old Sep 25, 2010 | 08:04 PM
  #125
Ozzfest's Avatar
Man those are pricey. Looks great on your G though.
Old Sep 26, 2010 | 12:44 AM
  #126
altimamark's Avatar
Great job i would like to do the same install
Old Sep 26, 2010 | 07:05 PM
  #127
djfarhan's Avatar
thanks for the info
Old Sep 27, 2010 | 01:58 PM
  #128
VatosLocos35's Avatar
what do you think about putting 3500k JDM yellow HIDs in the OEM fogs for the 06 projectors? has anyone tried this?
Old Sep 27, 2010 | 04:15 PM
  #129
kmuniz78's Avatar
Why? This thread is for 2007 and above, not 06's. Ask in the other forums.
Old May 18, 2011 | 07:22 PM
  #130
andruha88's Avatar
Originally Posted by salvador312
You want budget!!! Then get some fog lights from pep boys or autozone. I wish some vendor would come out with a nice looking kit.
the blazer for light kit from trs seems good enough, and its small, i am thinking about using it for a retrofit, what you think?
Old May 18, 2011 | 08:59 PM
  #131
soundmike's Avatar
Cutting the hole isn't really an issue, but i'm still trying to figure out is how to mount the fogs to the bumper itself without worrying about excess heat melting the bracket through the bumper cover.
I've had a spare bumper all this time, and have stared at it for so long still trying to figure it out to no avail.
Someday i might just go ahead and mount it from the reinforcement bar and drop it down, out and through the bumper cover "vents".
Old May 18, 2011 | 09:14 PM
  #132
andruha88's Avatar
excess hear from what? engine? or projector?
Old May 18, 2011 | 09:24 PM
  #133
soundmike's Avatar
The fogs.
Old May 18, 2011 | 09:37 PM
  #134
andruha88's Avatar
what fogs were u planning on using? I was thinking of blazer fogs from trs, the complete kit is 170, comes with hid bulbs ballasts and relay wiring, i can prolly ask guy at trs hot hot projector get since they were doing some testings on it
Old May 20, 2011 | 01:47 PM
  #135
kmuniz78's Avatar
my kit was mounted to the bumper support beam. the fit is perfect. does that kit also come with the ballasts? If so, how did I miss it. Could have saved a few hundred bucks. oh-well.
