Euro Spoiler Installed
Jan 1, 2009 | 03:01 PM
Reply 0
Jan 1, 2009 | 08:12 PM
Where did you pick that up????
Reply 0
Jan 1, 2009 | 08:35 PM
Looks good , but holy smokes you are parked close to that Jag in front of you .
Reply 0
Jan 1, 2009 | 08:40 PM
very good
Reply 0
Jan 2, 2009 | 01:06 AM
haha no worries about the Jag, i do it all the time...for a person thats paranoid about my cars....you're right it is very close
but thank god not a single touch
usually i park it the other way around...the G on the inside..Jag on the out...the Jag has parking sensors in the front...so it helps a lot
Reply 0
Jan 3, 2009 | 10:30 PM
seriously, my palms are sweating because of how close they are.
Reply 0
Jan 5, 2009 | 10:42 PM
haha no worries...ive gotten a LOOTTT closer
but never have they touched =)
Reply 0
Feb 6, 2009 | 02:45 PM
Where and how much you get it for? Also, how did you install it? Screws or just some 3M tape? It looks nice, but I'm not sure if i want to drill holes in my trunk.
Reply 0
Feb 6, 2009 | 04:43 PM
I got it on Ebay, the item shows up every once in a while. Its a $90 peice...comes out to about 110 with tax.
you can screw it in if you want...but it does come with 3M tape attached to it already.
I installed it myself...literally takes 3 minutes. An extra pair of hands would help
Reply 0
Feb 14, 2009 | 06:29 PM
i saw it also on Ebay.... Did u even use the screws? Cause i was thinking about using the tape...How was the color match?
Reply 0
Feb 14, 2009 | 09:27 PM
^ the tape will hold it just fine (a good tape I should add)
to the OP:
Sweet job man, looks great!
Reply 0
Feb 15, 2009 | 01:35 PM
color match was excellent...right on cue.
No i did not use the screws because it is a lease. The tape holds up fine........
buuuuuuutttttttttttttttt.................... (and i really regret doing this)
there is a DIY on how to reduce the wind noise from the sunroof....and the other day was a nice warm day....i decided to drive with the roof open.
The whole trick is to push down the plastic piece that pops up when the sunroof is open....so while i was driving, i pushed it down with my finger to see if it makes a difference...and it did!.......but i guess it also made a difference with the airflow to the trunk
few minutes later......i hear a pop...and off went the spoiler =(
Reply 0
Feb 15, 2009 | 03:09 PM
nice!
Reply 0
Feb 16, 2009 | 11:37 PM
That sucks man. I bought one for my old maxima and used the screws was afraid that might happen. Good luck!
Reply 0
Feb 17, 2009 | 01:53 AM
yea the whole sunroof wind deflector trick isn't really that great of an idea. the deflector is there to keep the wind out of the faces of your backseat passengers. so if you have nobody in the backseat, its cool. but it would be annoying if you had someone back there and the wind was in their face. and now u just added to the reason why its not a great idea, clearly it affects airflow to the trunk, which also means it affects coefficient of drag...the wind noise isn't THAT bad.
Reply 0
