Heat Proof JWT Intakes
Old Mar 18, 2009 | 12:54 AM
G35 {skyline}'s Avatar
I had to put my stock intake system back onto my car for R&D tomorrow for the RPi intake scoops....... so when i came to take out the intakes i touched the intake pipes and they were burning hot... and i mean BURNing hot. so i decided to head over to home depot and get some Thermal Tape... Well after about 30 mins of work here is what they look like.... by the way, the tape will keep the intakes cool and they can take up to 300 degrees F of heat.
Old Mar 18, 2009 | 02:47 AM
Borna's Avatar
I'm surprised the JWT's got so hot.
I heard they were supposed to be one of the best cooling short tube intakes, along with the K&N.
I guess I'll go for the K&N for my car, don't want my intakes to be burning hot...that can't be good for what intakes are designed to do. lol
Good idea on the thermal tape man, plus if you get the RPi scoops made (and they work) then it should stay relatively cool. You should ask them to build some heat shields for you.
Old Mar 18, 2009 | 02:49 AM
ttrank's Avatar
Grocery getter
You will be in the same situation with oem vs JWT. The heat tape will help both.
Old Mar 18, 2009 | 02:53 AM
Borna's Avatar
Yeah but the OEM intakes don't get so hot, I changed out my fogs after driving to my friend's place and I didn't have any problems touching the intakes with my bare hands.
Old Mar 18, 2009 | 05:13 PM
soundmike's Avatar
It probably doesn't matter much either way. The air is constantly moving up that short tract. It doesn't stay long enough inside the tract for the heat from the metal to significantly affect it. What matters more is the temperature of the air that the filter is sucking in.
Although the wrap doesn't hurt.
Old Mar 18, 2009 | 05:18 PM
Jeff92se's Avatar
Red Card Crew
What type of tape this this? I wasn't aware Hope Despot had this stuff.
Old Mar 18, 2009 | 06:32 PM
Actually the K&N intakes are more prone to heat since there is more metal used. And they dont get hot from driving around... they only get hot when you leave your car parked for awhile and since the hood is closed, the engine bay gets hot causing the pipes to heat up.
Old Mar 18, 2009 | 06:33 PM
There is actually no name on the cover lol.. It just says Thermal Wrap.
Old Mar 18, 2009 | 10:43 PM
kool_yaar's Avatar
that looks very professionally done, i might do that if it really helps, do post if you feel any difference that i doubt would be noticable, also the scoops taht you're getting they should be AF intake compatiable as well, so why go back stock?? i know it would show more gains, but IF you can do dyno with stock+scoops AND jwt+scoops, that would be really helpful. Thanks!
Old Mar 18, 2009 | 10:53 PM
ill make sure i post all the results and im also going to try to make an air box for my car kinda like the stillen one so the intake only takes outside air.. ill make sure to post pictures as i go forward.. and as far as the scoops go.. i think im gonna drop being the test car because i cant leave my car with them for a couple of days.
Old Mar 18, 2009 | 11:26 PM
The only reason i put my stock intakes on was so that RPi can look at the stock system. and thank you.. i take pride in my work lol
Old Mar 18, 2009 | 11:33 PM
sammy_G's Avatar
that stuff looks THICK! how many layers did you use?
Old Mar 18, 2009 | 11:57 PM
I actually only used one layer... i had one part of it go over to 2 layers close to the filter becuase i need it like that for my little project im trying =]
Old Mar 19, 2009 | 12:00 AM
GinFLA's Avatar
that actually looks like a good idea.
Does it really keep the intake temps cooler? I might just go out and get some of this thermal wrap and try this on my CAI.
Old Mar 19, 2009 | 12:24 AM
Im sure that it keeps temperatures lower because thats what its made for lol. but im going to install my intakes back on tomorrow and we will see if the piping gets hot... i also have another idea for us JWT users
