Newbie tire question
Old Nov 10, 2013 | 03:05 PM
OldG35x's Avatar
Hi
I'm about as newbie as it gets - I just bought a 2004 G35X and haven't even taken delivery yet. However, I seem to have already made my first mistake. I bought used winter tires on rims from someone who had gotten rid of his G35 (not sure what year - he said 2010, which would make it a G37 I think). The tires are 225/50/17 for front and 235/50/17 rear. The stock size for mine is 215/55/17. Is this gonna work? I am concerned about wheel offsets and the effect of the different diameters on the AWD and ESC/ABS. If necessary I could replace the 235's with 225's. Anybody got the answers?
Sorry if this is an old topic - I haven't searched extensively
Old Nov 10, 2013 | 06:42 PM
Urbanengineer's Avatar
There is a thread dedicated to this, but with my lesser knowledge I would say that you are okay and that running those tires should be fine.
https://g35driver.com/forums/wheels-...-ask-here.html
Old Nov 13, 2013 | 07:00 AM
OldG35x's Avatar
After reading over 100 posts it seems this is not a yes or no answer - my conclusion (so far) is that it is not recommended but not strictly prohibited either. I would not do it if I didn't already have the tires, but it seems they will probably not hit anything and the 1.5% diameter difference is below the 3% threshold for the ATTESA so I think I'lll give it a try. Others reported no problem even over the 3%. I guess if nothing feels funny and no warning lights come on then I'm good to go.
Any comments anyone?
Old Nov 13, 2013 | 12:35 PM
Blue Dream's Avatar
I drove ttrank's car solo
First off, offsets have nothing to do with the VDC being happy. As long as your tire's diameter F/R is within 3% of each other you will be fine so the new setup will work for you. It absolutely is a yes or no answer, stick to the 3% rule and all is well.
Old Nov 14, 2013 | 06:15 AM
OldG35x's Avatar
Thanks for the confirmation Blue
I know the offsets don't affect
Old Nov 14, 2013 | 06:19 AM
OldG35x's Avatar
Thanks for the confirmation Blue. I know the ofsets make no difference to the VDC, only to whether the tires hit anything. From what I've read there seems to be a lot of room in these wheelwells so within reason offset can vary (as long as the rim doesn't hit the caliper)
Old Nov 16, 2013 | 11:10 AM
OldG35x's Avatar
Hello again
Now that I actually have the car my concern is that the winter tires will stick out 10 - 13 mm more than stock due to 35mm offset vs stock 45. From actual measurements it looks to me like a problem but is it?
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
